centrifugal clutch
vachon644
95
Quebec city, QC, Canada
@Jeremy : It's not normal to be unable to idle your engine; You either have air/fuel problems or clutch problems. Most commonly it will be a problem with the clutch cable tension, it might be necessary to open the clutch cover and remove a notch on the flower nut. Also, you might have an air leak which could cause all sorts of symptoms such as the engine still revving for a few seconds after releasing the throttle. Also, yes a centrifugal clutch would allow to idle a chinagirl/HT engine without using the clutch.
zean
321
216
43
california
Is it regular motorcycle engine oil you're adding to your BT80 clutch bath oil not synthetic? I've read some knowledgeable people using 80-90 weight gear oil to help that clutch run smoother with good results. I think the manual said regular 10-30 wgt automobile engine oil. I would have used motorcycle clutch bath oil.
cannonball2
3,682
221
Colonial Coast USA.
I have run 80/90wt from the get go with zero issues. Quietens the gears a bit too. The BT80s clutch is excellent. Mine engages a a fairly low rpm and easily pulls from stop with a fairly high ratio. I also have a normal CG cent. clutch which is the dry type. It works well but is not in the same league as the wet clutch.
  • Like
Reactions: indian22
