Hi all.
I bought two engine kits and have them both installed on two bikes. Was out last night, with a friend. He turned his off with the kill switch and then couldn't start it again. It was pitch black and after some faffing we saw that one of the wires at the connector had come out, we plugged it back in and it still would not start. As it was too dark, we rode home normally to sort it out in the morning.
I've been fiddling with this thing all day and I can't get it to start. It even more annoying as I am a mechanic!!
The kill switch is fine, I've had it apart and no probs there. Engine will also not run with switch not connected.
Spark. I have a healthy spark visible in daylight. I have also swapped the CDI and plug from the other bike and it sparks just as well, as does the suspect CDI on the other bike. So that has totally ruled out the CDI and/or magneto and/or spark plug.
Fuel. The plug is stinking of fuel. No blocks anywhere. I've had the carb to bits and inspected for anything blocking jets that might be causing it to flood. All is clean. I've also left the plug out for a few hours to let some of the fuel vapour out after lots of failed attempts.
Air. I've had the filter off, it still won't run.
So to summarise, I have a good spark, a good amount of fuel, all the air it wants, but it won't run.
This brings me to the final point. Compression. Pushing the bike along with the clutch out, is hard and when trying to kick start it, it is just as hard as the kit on the other bike. The clutch does not appear to be slipping.
This engine was running very well yesterday. It was noticeable quicker than the other bike too. They are both running the same fuel/oil mixture.
I can't get my head around this! The other bike is fine, and even with all the bits from the other bike on the broken bike, it won't run! It could only be compression or clutch as far as I can see, and both of them seem totally normal.
Any clues guys?
Thanks in advance!
Any clues guys?
Thanks in advance!
