I would like to trade (9) 6mm X 1.0 lock nuts for the (9) OEM rag joint nuts. I will send the lock nuts, you swap them out and send me your OEM nuts.
Thank you
Ron
Thank you
Ron
You sir, are 100% correct. I installed the lock nuts on mine, and have run out of my preferred nut, although the thinner nuts that I can buy will work.i have a feeling there is some method to his madness...i am curious though.
I hope you never have to remove those...why dont you just run to home depot or lowe's or any hardware store and get them? the nuts on my rag joint are from home depot and they fit just fine. i put red loctite on them and they stay put. had this wheel for two and a half years now.
You are right... I do use red on studs, but heat will be needed to remove. Red on a rag joint is for duration.I hope you never have to remove those...
I guess you didn't read the posts in this thread.just buy 18 of them at home depot, then braze two together on each hole.
lol, lol, And I'm really laughing.....daaa From someone who uses red on the rag joint bolts/nuts, and hopes he never has to replace a spoke.Ummmm yeah.
