So a couple weeks ago I put on the SBP shift kit on my 66cc. Love the low rpm cruising but before the shift kit I could hit 35 (maybe 36 on a good day) with a 44 tooth. The motor screams. So I figured with the shift kit Id be hitting around 40 at least. Nope, cant get above 32. I have an 8 speed bike, and Ive tried top speed in 4-8th. 5th is the best at 32, but 4th will pull good right up to 30. I noticed I had a worsening head gasket leak, so spent a couple days perfecting the fix (glass and sandpaper to flatten my anglefire head). That got me from 30 to 32 top speed. Also I found an intake leak where the carb connects and fixed that (sprayed starter fluid and now its perfect). The shift kit chains are not too tight. Cant think of what is slowing me down.
I have the NT carb on the stock air/fuel ratio and thats worked great. stock jet but I have a 68 n 66 if I should try those. At full speed I tried slightly choking the motor to make sure it isnt running lean, and it just bogged and slowed. so maybe its rich at full speed? Also It feels like its hotter than it used to be. Lean? Maybe thats the raised compression with the head sanding or it could just be me.
Also Im at sea level if that helps for tuning tips.
My spark plug is brown, but maybe 3 months old. Does the color reflect the tune of the last ride or average tun of the life of the plug?
