First time installing...My clutch is so stiff/firm that there is no way my clutch cable and hand lever can pull back the clutch arm to disengage the clutch and allow the back wheel to spin freely. The only way i can disengage the clutch is with my hand and it takes alot of pressure to do so.
I tried adjusting the clutch but it didnt make the clutch arm any easier to pull back(and disengage the clutch). And when i was feeding the chain through i felt that might have had something to do with the stiffness in the clutch arm, because i thought it was looser before i fed the chain through. As i was feeding the chain through the pin and little ball bearing fell out, but now the ball bearing doesnt come out. So anyone know what going on? Thanks a ton.
