Old 07-30-2009, 01:06 PM
robin's Avatar
robin robin is offline
Exclamation SCSW tuned pipe & carb $150
These are performance parts for the 2 stroke which iam parting out because my HT engine seized
$150 for both see pic of pipe
Old 07-31-2009, 11:14 PM
donuts31 donuts31 is offline
Default Re: SCSW tuned pipe & carb $150
What is a SCSW tuned pipe? is it specifically made for the HT engine? do you have a link that I can get more info about it?
Thanks!
Drew
Old 08-01-2009, 01:46 AM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Santa Cruz Scooter Works
SCSW pipes are made at Pipelyne Manufacturing. Dean (the owner) has been making two cycle pipes for 30+ years. We've tested 6 different pipes and this pipe worked the best "hands down" The pipe design came form BZM's 50cc race pipe. The header pipe was extended a few inches to help with the low and mid range. It comes with a heat shield so it doesn't get hot. The carb is a pulse carb not a gravity fed carb. It's easier to tune and there's no need to change jets or move the clip. It has a high and low jet screws. If I remember correctly. I had my L screw set at 1 5/8 turned out and the H at 1 1/4 turns out.
Old 08-06-2009, 03:09 AM
Mike Hunt Mike Hunt is offline
thats a nice pipe.
is it for the 49cc or the 66cc engine? how loud compared to stock?
tell me more about the carb.
Old 08-06-2009, 10:46 AM
robin's Avatar
The pipe is for both engines--it depends what stinger (the muffler on the end) you use as to how loud it is--the one pictured that i will supply is louder--i also will supply a stainless steel thermos bottle packed with stainless steel wool that makes it quieter than the stock.
Old 08-06-2009, 12:42 PM
interesting, so how much of a performance increase do you get with this pipe? also, please do tell more about the carb.
