Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Wheels, Brakes and Suspension
Wheels, Brakes and Suspension Keep your motorized bicycle on the road with suspensions, rims, tires and disk, drum and caliper brakes
Old 07-29-2009, 01:51 PM
13b 13b is offline
Default coaster brakes help?
i just bought another bike (after wrecking the first one) to put a motor on. it's a really old fixed gear with coaster brakes. what do i need to make the coaster brakes work with the rear sprocket?
i also have a few more questions:
what do i need to do in order to use a stronger chain?
can rear sprockets be purchased to affect the gearing? what size would be suitable for a 26" cruiser?
are those sprockets compatible with a stronger chain?
really more than anything i just need a laundry list of things i need to make this work.
Old 07-29-2009, 04:14 PM
Cabinfever1977's Avatar
Default Re: coaster brakes help?
you take the coaster brake off,mount the sprocket,then put coaster brake on,thats it.
you can use a stronger chain right now with the stock sprockets.
you can buy diffrent size rear sprockets,it will effect you top speed and acceleration and torque. i use the 44t sprocket and it works good. and you can use a stronger chain on the stock sprocket.
Old 07-29-2009, 05:29 PM
rockvoice's Avatar
rockvoice rockvoice is offline
actually, you need to grind down the dust cover for the bearing on the coaster arm side. trim it so its just a hair inside the hub instead of having the crown around the outside of hub.
if you just take the arm off and install the sprocket the wheel will not spin.
Old 07-29-2009, 05:32 PM
Finfan's Avatar
Finfan Finfan is offline
You'll probably have to mod the dust cap so check out this thread: http://motorbicycling.com/f30/coaste...-mod-1841.html
You'll also have to bend the brake arm a bit. There are instructions for that on the Spooky Tooth site.
I use #41 Roller chain which is plenty strong, although #415 chain will also work. The 44 tooth sprocket works fine for me on a 26" cruiser. The lower the tooth count the lower the torque and the higher the top end speed.
Good Luck!
-and-
I'm not lost, I'm exploring!
Old 07-30-2009, 02:44 PM
o yeah i forgot to mention i took off my dust cap to mount my sprocket,but you will probally want to just modify your dust cap and put it back on.
