Old 07-28-2009, 11:35 PM
gohst ryda gohst ryda is offline
Default lean or rich help/
with my expansion chamber added to my 69cc i need more top end
thew plug is black, do i need more fuel getting in or do i need to add more oil????
im confused?
Old 07-29-2009, 12:26 AM
Pablo's Avatar
Pablo Pablo is offline
Default Re: lean or rich help/
How much oil are you running?
How are you checking the plug? (best is after a hot hard run)
When someone is talking about tuning lean/rich refers to your air/fuel mixture (not the oil)
Sounds like you might be slightly (fuel) rich. What notch are you running?
Old 07-29-2009, 12:31 AM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
this post should help answer some questions for you, http://motorbicycling.com/f30/how-re...html#post89518
has pics too
Old 07-29-2009, 02:10 AM
Sydneysider's Avatar
Sydneysider Sydneysider is offline
Blocked or restricted mufflers can make plugs black just like too rich fuel mixtures. If the problem occurred just after you put the expansion chamber on, Id say it would be that..
"....dunno what I did to my engine the other day but now my rear tyre wears out real quickly..."
Old 07-29-2009, 10:14 AM
freewheeling frank freewheeling frank is offline
sounds like your running to rich, or too high oil to fuel ratio
Old 07-29-2009, 10:23 AM
Pablo's Avatar
It's pretty common to be forced to re-jet when installing a tuned expansion chamber, it's what tuning is all about.
