Old 07-29-2009, 10:02 PM
Cabinfever1977's Avatar
Default Re: Engine on order, Hooray!
after my fender broke it didnt come all the way off but it was real loose.
i took it off and saw that the thin fender mount tab broke off.
the tab is held on to the fender by 2 ribbetts, the tab bolts to the bike threw a hole.
i took off fender and drilled out the ribbets and the tab is off,
next i found a small steel "L" shaped braket and bolted it in place of the tab on the fender.
washers may be need if drilled holes are bigger than bolt.
and i bolted that to the bike the same as the stock tab. i also added a thin piece of rubber between fender and bike to stop vibration.
Old 07-29-2009, 10:14 PM
Rambler Rambler is offline
Alright sounds good, thank you for the tip, I will definitely look into doing that as soon as I can. How about the rear fender, do I need to do anything about it?
