07-28-2009, 10:31 PM
Engine on order, Hooray!
Now it's just a matter of time, I hope it is fully intact when it arrives, as this is my first attempt at a build, or anything to do with small engines for that matter. Does anyone have any preparatory tips, like what kinds of tools/whatnot I'll need to acquire.
07-28-2009, 10:36 PM
Re: Engine on order, Hooray!
small adjustable wrench
gas resistant(yellow) teflon tape to put around threads on fuel tank petcock
o-ring for carb to intake : 5/8"id 3/4"od x 1/16" wall
tube of high temp silicone sealant to be used around intake
philips screw driver and flat head screwdriver
plastic ties and black tape
small pliers and/or needle nose pliers
small wire cutters to cut off extra clutch cable and other stuff
07-29-2009, 12:39 AM
Ok, thanks. I think I have most of those items laying around.
I am going to mount the motor on a Windwood, and am curious as to what type of brakes to use, will bmx side-pulls fit over the fenders or will I have to take the fenders off? I am looking for the penny solutions as opposed to the ten dollar solutions. What are some must haves, front brake obviously. Anything else safety wise that you can think of?
07-29-2009, 08:36 AM
A helmet.
Check your bike before each ride, like a pilot would pre-flight an airplane.
07-29-2009, 08:37 AM
07-29-2009, 10:01 PM
Thanks for the link. I am glad I found this forum, very informative, and nice people to boot.
07-29-2009, 10:38 PM
make sure your front fender has a strong steel mount.
07-29-2009, 10:45 PM
How do I go about doing that? Will I need to weld on a bracket, or is there another way to mount it?
07-29-2009, 10:52 PM
what kind of bike do you have?
on my swchinn del mar i drilled out the ribbets on the stock fender mount and bolted a small steel L mount and put a thin piece of rubber between the fender and fork.
the stock fender mount vibrated and broke,i took off fender to drill.
07-29-2009, 10:54 PM
It's a cheapie, a Schwinn Windwood. So basically a red Del Mar.
| Thread Tools |
| Display Modes |
Linear Mode
