| Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. |
07-28-2009, 07:11 AM
My Bike Only Goes Fast
I finally got a chain on my bike and it's running smooth. Not falling off or anything like that.
Now my problem is the throttle seems to do nothing. I pedal start my bike and it just starts going really fast.
Anyone know what to do?
07-28-2009, 08:00 AM
Re: My Bike Only Goes Fast
Check your throttle slide, it may be in backwards.
Also check the slide, cable and throttle twist grip for any binding.
07-28-2009, 08:08 AM
Which way does it go in? Does the slide slide all the way down or do you line it up with the notch on the other side to stop it?
I have it so the notch catches on whatever is in there, should I turn it around?
07-28-2009, 08:32 AM
Ok I just turned it around and it now works. Thanks for the help.
07-28-2009, 12:21 PM
Hey, my throttle seems to stick every once in a while, last night i was coming to a stop light and dident realize and luckly killed my engine quickly, it get caught on something inside the carb, the slider is in the right way, if i play with it usually i can hear the spring reset. Also when i untwist the thing were the slider goes into the carb, its not a smooth fit like it once was, ive cleaned it and felt for debris and there is nothing. Im stumped on this one
07-28-2009, 01:49 PM
make sure there are no kinks in the cable,also if you have it tied down make sure its not too tight
07-28-2009, 02:16 PM
also the hat screw that the throttle cable goes into can be to tight and make it stick try that
if you dont see smoke your doin somthing wrong fly low beat the radar
04 shcwinn 80cc dax sbp camber cns carb boost bottle k&n filter 36 tooth 40mph (gps tested) havin fun and smokin scooters
Ive already done that, i believe its getting snagged somewhere in the carb, anyone else throttle do this?
07-31-2009, 11:49 AM
My throttle only goes fast as well.. I have no idea how to fix this
07-31-2009, 02:52 PM
clutch cable should not be tied tight to bike.
And where it screws into the top of carb should be hand tightened.
Carb slide will have a groove up and down one side of slide and a notch at bottom on the other side of slide,the groove side of slide goes toward right peddal side of bike and the notch side of slide goes toward the carb set screw. a drop of oil rubbed all over the slide before inserting into carb might help.
| Thread Tools |
| Display Modes |
Linear Mode
