Old 07-27-2009, 10:00 PM
joeblow's Avatar
joeblow joeblow is offline
Smile bike with gas tank in frame?
I was looking on Grubee Inc. and they have some bikes with a gas tank built into the frame. They are nice looking cruisers too. they only wholesale them and it looks like they will only sell 260 of them at a time, so I was wondering if anyone knows where to get one of these bikes.
It is a chinese make: fulihua gt-2
Old 07-27-2009, 10:15 PM
azbill's Avatar
azbill azbill is offline
Default Re: bike with gas tank in frame?
there is one on my local CL
Grubee GT2 Motorized Bicycle
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 07-28-2009, 11:39 AM
lordoflightaz's Avatar
lordoflightaz lordoflightaz is offline
Bill I saw that one, too. He sure does put out some nice looking bikes.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike.
If trailer parks didn't exist would tornadoes exist?
Old 07-28-2009, 11:44 AM
Dave31's Avatar
Dave31 Dave31 is online now
USABikeMotors.com, Star-Fire Motors and Parts
I was at USA and got to see the new bikes that have come in.
26" 18.5" frame : Straight slot drop outs; GruBee HD rear axle with engine sprocket attached.
· HD Steel Frame: Frame tube metal thickness is 1.6 to 1.8 mm. (Cheap bikes are 1.2 mm.)
Fork:
· 381DH Zoom Triple Tree dual head front fork & dual shocks with mounting bracket for disc brake:
Rear Axle:
· GRUBEE single speed HD rear axle with drum brake factory installed:
Peddle and Chain:
· RIGHT Rear: 18T freewheel sprocket for chain going to a 44T people pedal sprocket :
· 1 piece pedal crank for large bottom hole bracket; ( Wide pedal crank extra cost option: )
· Chrome Chain guard :
Brakes:
· Factory installed Caliper Vee Brakes on both front and rear wheels:
· Metal pull lever for HD axle drum brake cable:
· Dual brake cable throttle handle: 2 cables to Vee brakes operated by 1 lever:
Tires:
· 2.125 tires; smooth tread ; Tires marked made in China with PSI air pressure rating:
Wheels:
· 36 12 gauge spokes in Double wall heavy duty aluminum wheel rims front and rear:
· No fenders but designed so if customers want they can attach fenders of their own:
· 12 gauge. chrome spokes:
· Front wheel has Special HD axel from same supplier as HD rear axle.
· Front and rear wheels with yellow reflectors in spokes:
Gas Tank:
· Gt2 tank has beautiful Knight Hawk decal on both sides:
· Gt2 tank pressure tested at 90psi for leaks. Air gauged for one minute under water:
· Gt2 tank has small plastic gas fill cap; Use funnel to fill: Use tank valve supplied in engine kit.
Misc:
· Seat with knurled seat post
· Cruiser Handle bars made of steel:
· All bike components meet or exceed CPSC USA requirements.
· Frames wrapped protected and packed SKD in cardboard Carton.
· Gt1 Gross wt. 36.37 pounds / Gt2 Gross wt. 38.58 pounds
Old 07-28-2009, 01:09 PM
azbill's Avatar
they also have brackets for bolting the engine to, I believe
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 07-28-2009, 03:56 PM
RedB66's Avatar
RedB66 RedB66 is offline
I emailed USABikes and the reply was that he would offer "Just the Frame" when he figured out a price.
MOTORBICYCLING.COM STICKERS
Old 07-28-2009, 06:20 PM
joeblow's Avatar
thanks for letting me know where to get one of these.
Can they be purchase as the bike alone without an engine from anyone? I have an engine.
Old 07-28-2009, 06:54 PM
broHSI broHSI is offline
Where are you located?
The frames do not have brackets for bolting the engine to.
Old 08-28-2009, 10:40 PM
javelina1's Avatar
javelina1 javelina1 is offline
bought my Grubee Gen II motor from him, (the local CL). He's a good guy. Lives a couple miles from my house. I'm considering buying either the GT1 or GT2 kit from him now.
