Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 07-26-2009, 01:04 PM
fakeplay's Avatar
fakeplay fakeplay is offline
Default Engine to loud
Hi, how can I quiet my motor down. It's grubee gt-5 I just got. It's way, way, way to loud. Is there any special baffle I could get ? or how do I know if ones already in there. I mean this thing is loud !
Old 07-26-2009, 01:37 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Engine to loud
you have a picture of the pipe you can post? Is it new or used?
norms-iron-works.tripod.com
Old 07-26-2009, 02:27 PM
fakeplay's Avatar
It's new. It came stock with the grubee gt-5 kit Black pipe , I guess it's the new style.
Thanks No pic yet
Old 07-26-2009, 04:32 PM
Cabinfever1977's Avatar
it shouldnt be very loud,are you sure you put a gasket on it and have the nuts tight on it. if your exhaust is leaking where the muffler mounts to the engine,it will be a lot louder.
Old 07-26-2009, 05:15 PM
captainrichhill captainrichhill is offline
With just a little engineering you can add a "stinger" to your existing muffler. Look in your local home improvement/ small engine store for another small screw-on or bolt-on muffler and add it to your existing muffler with copper pipe couplings or something like that.
Unfortunately or fortunately this hobby requires the owner operator to get creative at times. let us know what you can come up with. I'm sure you're not alone on this topic. Please post results.
Old 07-26-2009, 05:26 PM
fakeplay's Avatar
Thanks I'll chech the bolts
Old 08-02-2009, 11:01 AM
SpandexOrLeather SpandexOrLeather is offline
I have the exact same engine kit, and thought it was loud also. However, now that some miles are getting on it, it's quieting down noticeably. Perhaps as things get worn in and loosened up a little, there's less noise from things moving around easier. Sorta like the fuel is being turned into motion more efficiently now, and so less of it is being needed to overcome internal friction.
Old 08-02-2009, 11:28 AM
dana's Avatar
dana dana is offline
Ok, PLEASE try this. Take the end cap of the muffler, pull out the baffle and push one
wad of steel wool in the pipe, and wrap one around the baffle toob. This made a huge
differance for me good luck!
Old 08-03-2009, 03:16 PM
the baffle doesnt come out of the new black ones.
