Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 05-13-2008, 02:56 PM
rawkstar320 rawkstar320 is offline
Default HHO Gas Mod - yay or nay?
I was poking around the web and ive seen this
"Learn how to mod your car so that it runs on part HHO gas so that your millage goes up and you save on regular gasoline."
Now, i believe that this is extremely possible...with a big 4 stroke engine...but would you have issues with running the same theory on a little 2 stroke engine? GRANTED you already get like...150mpg. BUT wouldnt emissions be down? (again..they are already low..but lets have fun here..)
Would you have trouble with the fact that there may not be enough oil to keep the engine from wearing faster?
hmmmmmmmmmm
I dont know a whole lot about the diff between a 4 stroke engine vs a 2 stroke except that 2 strokes are said to be dirtier because you burn the oil WITH the gas.(makes sense)
Any input?
I would think you could set it up just like the nitrous setups. Except it would always be on and we wouldnt be trying to give a boost. Just a little extra power(if reasonable0 and the ability to say "I get 1000000mpg on my bicycle"
haha
input?
Old 05-13-2008, 03:11 PM
Ilikeabikea's Avatar
Default Re: HHO Gas Mod - yay or nay?
I don't know much about HHO either. But I think you use electrical current in water to separate the molecules. With these bicycle motors you have very little electrical output. So I don't know how effective it would be. Very interesting subject though and I would love here what someone that really understands has to say on the subject...................
Old 05-13-2008, 06:04 PM
That is true..i was trying to think about how you could get more current....not to mention you would have to house the water and what not..
Old 05-24-2008, 02:18 AM
Padanew Padanew is offline
HHO gas is also known as Brown's Gas
Old 05-24-2008, 09:42 AM
Pablo's Avatar
Pablo Pablo is offline
And mostly a gimmick.....you aren't gonna get something out of nothing. The amount of energy required is not available and if it were, then there still would be a net loss....
Let's look at it this way - look what the car makers have done to make the clean burn 2009 USA diesels....some even carry 10+ gallon urea solution tanks for ammonia streaming conversion in the exhaust....now don'tcha think if the capitalists would do such a thing, they would have made commercially available brown gassers???
Old 05-24-2008, 12:49 PM
I'm always a synic. So since I think that way I figure if the hho was really viable, and GM could make a Suburban that would get 50 mpg, they would do it. Cause it would sell like hotcakes.
But I'm glad not everyone is a synic like me. Cause heck before Wilbur and Orville the "experts" said powered flight by man was impossible............
Old 05-24-2008, 01:55 PM
Dave31's Avatar
Dave31 Dave31 is offline
http://waterpoweredcar.com/watercar.pdf
YouTube - Stan Meyers water powered Buggy
If you go to youtube and type " John Kanzius " in search, you will find lot's of videos by this professor on how to turn water into fuel.
Old 05-24-2008, 10:42 PM
cityevader's Avatar
cityevader cityevader is offline
Actually, there is not much electrical current draw, which is greatly offset by power output of the fuel. Do you get less fuel economy with your headlights on vs. off? Measurable? Not likely.
My neighbor has been fooling around with this for about a month, and has gone from 25mpg to 35mpg.
I can only guess the reasons manufacturers aren't diving in is because of vastly differing variables, such as water quality, etc... however, the most crucial thing is that it requires diligence on the owner's part to be on top of things and making sure levels/concentrations etc are proper. You wouldn't believe how many engines I've replaced because customers simply drove their cars thinking they didn't have to do anything except put gas into it. "I have to change the oil?" Manufacturers perhaps don't want to get a bad rep because their products aren't being used properly.
Here's a good example, the Ford Escape Hybrid is advertised as getting up to 45mpg (when battery only mode fully utilized). So people don't think or even read the labels, and complain when they're getting "only" 32mpg. But the morons think they can drive the way they used to and get better economy, but they never even drive under conditions where they engine will shut itself off.
Who will save us from ourselves?
Old 05-27-2008, 05:13 PM
spad4me's Avatar
spad4me spad4me is offline
Please keep an open mind.
Naudin is one of two websites that offer free stuff and encourage duplication. They will post your work , IF IT IS GOOD ENOUGH, if you want it.
BingoFuel (Alternative Fuels researches) by Jean-Louis Naudin
Water should boil at 82 degrees Farenheight. This is a fact
Water actually boils at 212 Farenheight. This is a fact.
Why?
Hydrogen Bonding in a H2O molecule.
Now I want a catalist, or process, that will not only lower the boiling point, but will also disassociate the hydrogen from the oxygen.
Build a plasma reformer!
From naudins site Quote The bubbler is a tank containing a mixture of water and hydrocabures (gasoline, diesel, kerosene, crude oils and others derived from hydrocarbons...).
The hot gas flow coming from the exhaust of the engine circulates by the outside part of the reactor with a strong kinetic energy, that contributes to bring up to very high temperature the steel rod (being used as heat accumulator) contained in the pyrolytic chamber. (MUFFLER???)
Build a bingo fuel reactor and try it for yourself!
Or even wood gas.
Prior to 1940, gas generator units were a familiar, but not extensively utilized, technology. However, petroleum shortages during World War II led to widespread gas generator applications in the transportation industries of Western Europe. (Charcoal burning taxis, a related application, were still common in Korea as late as 1970.)
A bar-b-que on wheels used for cooking as well as fuel.
The material available through this site may be freely used for attributed noncommercial educational purposes only. We ask that due credit and notification be given the author.
Please be careful!!!!!
Look up LIFTER if doubt troubles you here.
This place is about science.
Old 05-27-2008, 06:00 PM
I'm glad everyone is not a synic like me. I enjoy being proved wrong. But here's what gets me with the hydrogen gas thing. It's called the first law of Thermodynamics.
"The First Law states that energy cannot be created or destroyed; rather, the amount of energy lost in a steady state process cannot be greater than the amount of energy gained".
But hey I'm glad there are people that think outside the box.
I'm really enjoying this thread. Ya'll keep it coming...................
