Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Old 07-23-2009, 12:19 AM
sxemike13 sxemike13 is offline
Default whats a good welding unit
so im just getting into bike building ive already built one bike by just taking from here and there and bolting and screwing things together but now im looking into doing some real building and was wondering what is a good welding unit to buy im not looking to spend a ton of money and i don't know how to weld but im a good hands on learner so any help would be nice thanx
Old 07-23-2009, 01:19 AM
DOC BOLM's Avatar
DOC BOLM DOC BOLM is offline
Default Re: whats a good welder unit
If you dont mind spending 480.00 HOBART makes the handler 140 mig.I have 2 of them .They are 110volt machines.I keep 2 of them hooked to each of my lincoln pipeliner 200 amp stick welders.You can weld stainless,mild steel or aluminum with or without shielding gas.HD
You never know what you might know,you know
Old 07-23-2009, 08:07 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
I bought a "cheapo" 110V wire feed welder off craigslist for $75. I've used it to weld a few cracked frames with very good results!
Old 07-23-2009, 11:38 AM
thanx for the feedback guys
Old 07-24-2009, 12:05 AM
2door's Avatar
2door 2door is offline
Mig, or wirefeed is probably the easiest to master without lots of practice. You can weld thin material as well as the thicker stuff up to 1/4" with most of the 110 volt machines. I'd shy away from the real cheapo ones seen at the big box and department and auto parts stores. Many of them are made in China or Italy and if you ever need replacement parts they are nearly impossible to get. Spend the few extra dollars and buy a Hobart, Miller or Lincoln welder. You can use the flux core wire and not need a tank but the C-25 (Argon/ CO2) gas makes for beautiful welds without the splatter of the gasless wire.
Old 07-30-2009, 12:48 AM
EsQueue EsQueue is offline
I have a great stick welder. A miller maxstar 150 stl. The only thing is that it is horrible with thin metals. It has a hotstart feature which spikes the amperage on the first strike in an effort to combat sticking. The problem is that this will just blow holes in metal 1/8" or thinner. I had to fight with the welder to just complete some simple welds.
If that feature wasn't added or gave you the option to disable, I would love that welder. Wire feed is the way to go.
Old 08-07-2009, 11:13 AM
Junster's Avatar
Junster Junster is offline
I have a Hobart Handler 120. It's a 220v wire feed. Like 2door said you will need tips etc. and if you put out a few extra dollars for a name brand machine the consumables are easy to find. The main difference with a 220v machine is you can weld alot longer before the machine needs to "rest" (duty cycle).
Put something FUN between your legs..
