| 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! |
07-22-2009, 07:03 PM
Engine Break-in
Ok, so I have my engine running smoothly, but I'm not sure about the break-in period. The instructions say not over 20 KPH for the first 300 KMs and on another page it says the first 500 KMs and on another page it says the first 85 KMs. Which is it?!?! I'm dieing to open that throttle up and really RIDE!
07-22-2009, 07:22 PM
Re: Engine Break-in
i would say around 20mph for 30mins at a time and vary your speeds. and do that for 2 tanks of gas.
but maybe someone else might have a better answer.
07-22-2009, 07:49 PM
Re: Engine Break-in
I don't think you have to wait two tanks of gas before opening the throttle. I certainly didn't with the seven I have built. Took it easy for the first 10 or 20 miles with a 20:1 mix then pretty much drove them the way I was planning on.
They really won't run up to speed until you get around 200 miles on them. At least that is the way mine were.
After a couple hundred miles I went to 32:1 mix. Now I am currently running the Amsoil saber at 50:1 and the four I have left all run very well.
John
07-22-2009, 10:53 PM
EZ Motorbikes Dealer
Re: Engine Break-in
From day one I have run Amsoil Saber Professional at 50:1. I didn't really do a break in, just varied my speed, sometimes opening it up, sometimes putting along, mostly just riding my bike. The first one has about a thousand miles on it and the new motor has a few hundred. No problems. Amsoil is good stuff. According to the manufacturer you can mix at 100:1 for small 2 cycle engines, but I never did. I also use it in my chainsaws. No smoke.
Silverbear
07-23-2009, 12:02 AM
Re: Engine Break-in
try googling <mototuneusa break-in> for the method i am following at the moment for my grubee Skyhawk 48cc .
07-28-2009, 11:50 AM
Re: Engine Break-in
I have a question about the brek in peroid and im sorry if this has been asked before but im planning to take the bike from deltona fl to orlando fl wich is about 27 miles away and i dont want to push the engine too hard so whats the maximum safe mph i can take the motor up to my plan is to ride the 30 minutes and then shut off the motor to cool down and pedal the bike till cool down is complete
07-28-2009, 03:29 PM
Re: Engine Break-in
i just go the speed limit which is 20 mph take it easy you supposed to take it easy for the first two tanks at 20:1 after that i will go to 32:1 or
i will run the amsoil oil at 50:1 or 100:1 a heard this oil is really good for two strokes engines
08-02-2009, 01:08 AM
Re: Engine Break-in
Here is some more real-life experience.... I started my engine breakin at 24:1 with mid-grade (I suppose) 2-cycle oil meant for AIR-cooled motocross engines. My first tank max speed was 15 mph. My second tank (still 24:1) was max speed of 20. My third tank (today, still 24:1) max speed was mostly 25 mph, sometimes wide open. I purposely keep the oil content high and will do so for another tank or two (opinions vary of course). My third tank lasted 70 miles (a single ride, was great!); about a mile per ounce of fuel. A long hill I pulled at 70 miles on the odometer needed pedal assist. Today, at 125 miles, that same hill did not require pedal assist. Maybe I will go 28:1 on my next tank.
MikeJ
08-02-2009, 05:07 AM
Banned
Re: Engine Break-in
IMO, don't listen to anyone about oil/gas mixtures. Listen to your engine... IN MY experience synthetic for "break in" = baddd... 3 gallons of Lucas semi-synthetic @ 16:1 = phail.. switched to 16:1 regular 2 stroke.. 3 gallons 650~ miles later my rings still aren't set......
don't be afraid to WOT it in bursts though...
(take it with a deer lick cube of salt, as with *most* of the "advice" on here)
08-02-2009, 09:38 AM
Re: Engine Break-in
16:1 with synthetic is so much overkill, It funny!
The main thing is this- don't make it too rich, and vary your throttle and engine speed for the first couple of tank fulls of fuel. Don't be afraid to rev it once in awhile after the first five minutes of running.
| Thread Tools |
| Display Modes |
Linear Mode
