Old 07-22-2009, 12:25 AM
sofasurferlinux sofasurferlinux is offline
Default Oil dripping from exhaust
I am running somewhere around 20:1. I noticed that at the end of my muffler the chrome is covered with oil. Then I also saw a couple of drops of oil on the driveway. Is this normal? Excessive? A sign of trouble?
Old 07-22-2009, 12:45 AM
city of angels city of angels is offline
Default Re: Oil dripping from exhaust
yes this is normal i had the same problem if this is your second tank or if this your third tank if it is you third tank i will go to 100:1 amsoil i heard really good stuff about i got a free sample i am going totry it once i run this last tank
Old 07-22-2009, 05:33 AM
Sydneysider's Avatar
Sydneysider Sydneysider is offline
yea its normal 'cause youre running 20:1.. on less warm days you can go atleast 25:1
"....dunno what I did to my engine the other day but now my rear tyre wears out real quickly..."
Old 07-22-2009, 05:44 AM
Bikeguy Joe's Avatar
Go to 24:1 (dino oil) to 40:1 with synthetic after break in.
20:1 or 16:1 is just too much oil.
Old 07-22-2009, 06:47 AM
silverbear's Avatar
silverbear silverbear is offline
EZ Motorbikes Dealer
City of angels said...
"yes this is normal i had the same problem if this is your second tank or if this your third tank if it is you third tank i will go to 100:1 amsoil i heard really good stuff about i got a free sample i am going totry it once i run this last tank"
...I've been running Amsoil Saber Professional since day one on both my engines at a ratio of 50-1 with not problems at all. The one engine from thatsdax has a lot of miles on it, maybe a thousand. The newer one from BGF only has a few hundred. I don't really do break in, just ride them, but at the same time I don't wind the motors out to see what the breaking point is. I weigh two hundred pounds and there are some pretty steep hills up my way in northeastern Minnesota. I also use the amsoil in my chainsaws so I don[t have to breathe the fumes of normal mix with regular oil. I'm very impressed with the stuff. If you choose amsoil synthetic make sure it is the one formulated for small air cooled engines... Amsoil Saber Professional. I'll be interested to hear how it goes with a mix of 100-1. Fine I suspect. Someone mentioned in another post how expensive the synthetic oils are. I don't look at it that way. With this amsoil you're using less oil per gallon and besides, we don't use that much gas anyway. I wanted to use the best oil I could to keep my motors going. I think this is it. No, I don't sell the stuff.
Silverbear
Old 07-22-2009, 01:54 PM
Cabinfever1977's Avatar
its normal for oil to be around the end of the muffler and to drip a few drops after turning off,especially during breakin.
Old 07-22-2009, 08:44 PM
Outrunner's Avatar
Outrunner Outrunner is offline
Silverbear
I've been using Amsoil for several years with a 50:1 mix. I use it for ALL of my
2 stroke engines too. It doesn't smoke, won't seize the piston, breaks in brand
new engines perfectly from day one. You can't beat it. Plus it SAVES you lots of
money, by reducing engine wear and damage, thus lasting longer.
Change is inevitable and progress is OPTIONAL!
Old 07-22-2009, 09:01 PM
Where do you buy Amsoil? The auto parts stores near me do not have it, that I have seen so far.
Old 07-22-2009, 09:17 PM
silverbear's Avatar
Sofasurferlinux asked,
"Where do you buy Amsoil? The auto parts stores near me do not have it, that I have seen so far."
I believe you can buy it online from the manufacturer and if you go to the website it will give you a lot of information on the oil for two strokes. I think ebay sellers list it as well. Look in the phone book for an amsoil dealer in your area. Some gas stations up my way carry it and once in awhile a Napa store will have it. Or ask around. Your small engine repair guy probably knows. I hope this helps.
Silverbear
Old 07-22-2009, 10:12 PM
Finfan's Avatar
Finfan Finfan is offline
Or check with Pablo! AMSOIL PRODUCTS
-and-
I'm not lost, I'm exploring!
