Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 07-20-2009, 07:29 AM
Hot Wheels's Avatar
Hot Wheels Hot Wheels is offline
Default 49cc or 80cc ?
Hi everybody, How can you tell from just looking at the motor if it's 49cc or 80cc. I bought a gas bike at a garage sale for 75.00 bucks. Thanks for the help !
Old 07-20-2009, 11:43 AM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: 49cc or 80cc ?
There is no way to tell what size motor you have just by looking at it.
Old 07-20-2009, 03:58 PM
Cabinfever1977's Avatar
is there a metal plate on the left side of the engine with any info on it?
do you have a pic?
Old 09-13-2009, 03:16 AM
Big Jim Big Jim is offline
The 49cc has a round head and the 80cc has a square head. OK,I was wrong but it is 1 thing to go buy.
Old 09-22-2009, 11:35 PM
mick29 mick29 is offline
I found the 50cc has 6mm head barrel bolts and 70cc has 7-8 mm bolts but it could be differant on different makes thanks mick29
Old 09-23-2009, 09:24 AM
Bikeguy Joe's Avatar
Not all the 50's have round heads. I have two 50's, a "65cc" and a couple of 70's here, and none are the same. One 50 has 8mm studs, the one 70 has 6mm studs.
The only way to tell is to measure the bore and stroke.
Old 09-23-2009, 11:05 AM
stv1jzgte stv1jzgte is offline
yeh i got 2 50's wid square heads 1 slant
Old 09-24-2009, 05:40 PM
xlite xlite is offline
Head nut size is not a reliable way to tell. Not necessary to take it apart. Diameter of cylinder between the fins works every time. Obvious once you think about it.
Old 09-25-2009, 05:13 AM
On that note. All 3 50cc barrels (all 40mm bore) i have are 57mm square.
Hot Wheels if your barrel measures more it aint a 50ish
Old 06-07-2010, 12:00 AM
vincent713 vincent713 is offline
When you look at the head on the 49cc vs the 80cc, it's noticeably smaller.
