Old 07-18-2009, 11:19 PM
Bikedad1's Avatar
Bikedad1 Bikedad1 is offline
Default Squeaking with clutch in.......
When I am coasting down hills with the clutch in I hear a annoying squeak. From looking at the exploded views that Jim posted it could be a few things. Any ideas???
Old 07-20-2009, 09:25 AM
HT2005 HT2005 is offline
Default Re: Squeaking with clutch in.......
I had the same problem with my engine. Remove the clutch lever actuation arm plate cover (three screws) and take out the dowell that sticks out of the gear hole. Apply grease and reinsert into hole. If the metal ball falls out as well, then grease this too. This should fix the squeak.
Old 07-21-2009, 12:00 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
This is common on these engines... The squeeks on mine usually come from the pressure plates & the center puck cage... Dab the TINIEST bit of grease around the edge of the pressure plates, & in the bearings, & see if that helps you... Keep the grease away from the clutch pucks!!!
Do the dowell pin too as HT said.
Old 07-21-2009, 06:43 PM
Bikedad1's Avatar
Sweet thanks guys, this weekend I pull some stuff apart and check and grease some parts.
Old 10-11-2009, 11:28 AM
Prasinos's Avatar
Prasinos Prasinos is offline
can i get at the dowel from the clutch cover side of the engine, my engine ws shipped with the bolts way over torqued so i stripped one o them on the lever arm side...
Old 10-11-2009, 01:38 PM
marts1 marts1 is offline
I had the same problem with those bolts being way too tight. I don't have any impact tools so I used a little grinding disc on those bolts and made it so I could use a larger type slotted screwdriver. Didn't matter that I had to grind some of the coverplate accept for looks.
