Old 07-16-2009, 02:26 PM
bodydropped bodydropped is offline
Default afff another issue
ok since my bolt snapping issues i replaced one side of the block. now i have a seal leaking on the magneto side it actually came apart now it leaking and it keep stalling.
my questions are is there a seal i can pick up at an auto parts store that will work and how long can i ride like this? im at work and have to ride home spewing oily gassy goo....dang it! any quick fixes?
Old 07-16-2009, 02:35 PM
Cabinfever1977's Avatar
Default Re: afff another issue
maybe you can buy a roll of gasket material and you will have to cut it to fit your engine and match the old piece. the only quick fix i see is to use a tube of high temp silicone and put it along the line where the engine joins and where gasket is and where it leaks.
that might be enough to get it home.
Old 07-16-2009, 02:58 PM
2door's Avatar
2door 2door is offline
Body,
Only one place I've found for crankshaft seals. They are not available anywhere else that I looked and I did some searching. Here's the link and they are one of our sponsors.
Motorized Bicycle Engine Kits
Old 07-16-2009, 03:14 PM
Originally Posted by 2door View Post
Body,
thats what i figured,i knew i should have replaced it while it was apart all this over a 3.00 shaft seal.
ahh geez oh well i will order one and hope she gets me home today. thanks man
