Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Mounting Techniques
Mounting Techniques Every frame is different. Share and ask questions about mounting your motorized bicycle engine kit to your bicycle frame or bicycle rack
Old 07-14-2009, 09:57 PM
vicsvw vicsvw is offline
Default Stripped 6mm Threads
Vic's Tip *** If you have any 6mm threads that are stripped. Install heli-coils. But if you don't have the special tap kit here is the next best thing. Just tap the striped out threads to 1/4-20 american. The tap drill for the 1/4-20 is a #7 drill. But when the 6mm pulls the threads out it's just the corect size for taping the 1/4-20. No need to drill out the old threads.
Old 07-28-2009, 09:35 PM
andrewg225's Avatar
andrewg225 andrewg225 is offline
Default Re: Stripped 6mm Threads
how do you mount a sprocket to a chopper wheel? i want to put mine togeather
Old 07-28-2009, 09:57 PM
andrewg225's Avatar
do you have to drill though the wheel hub? or is there anouther way to do it
Old 07-28-2009, 11:08 PM
donuts31 donuts31 is offline
timesert inserts is what I prefer used to fix 3 stripped threads on one of my engines.
Old 07-29-2009, 02:06 AM
wildemere wildemere is offline
By 1/4-20 American do you mean UNC or BSW or just whitworth.
I have not heard of that measurement here in Australia.
Old 07-29-2009, 07:12 AM
Bikeguy Joe's Avatar
1/4-20 is 1/4 inch with 20 threads per inch.
SAE/American.
Old 07-30-2009, 10:03 AM
HoughMade's Avatar
HoughMade HoughMade is offline
I watched the video from Timesert and have been over the website- If I were using a Chinese 2 stroke, I would seriously consider installing Timeserts from the beginning, at least at the engine mounts.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 07-30-2009, 10:43 AM
broHSI broHSI is offline
Probably put timeserts on the exhaust port too as they fail fairly often as well because of the exhaust hanging off the studs.
Unfortuneately the Timesert kit is about $50 for the 6 mm size
Old 07-31-2009, 03:03 PM
HoughMade's Avatar
I've often been accused of taking an inexpensive hobby and making it an expensive one. I'd have to plead guilty to that.
Old 08-02-2009, 10:13 AM
One of my bikes now has 3 timesert inserts. The latest one is on the head-intake stud stripped out on me while repacing gasket.
