Old 07-14-2009, 09:11 PM
Rotor Rotor is offline
Default Felt tank question
I just purchased a Felt Twin cruiser, and was wondering what was the best method for a fuel fill on the tube tank? any suggestions or at least a nudge in the right direction would be appreciated.
Thanks, Rotor
Old 07-14-2009, 09:54 PM
Clotho's Avatar
Clotho Clotho is offline
Default Re: Felt tank question
Something like this. Filler cap
You know that you have to seal the tank right? It won't hold gas until you do.
__________________________________
Old 07-14-2009, 11:54 PM
I have read about sealing the tank. In the article I read on another forum they used brake bleeders to fill and vent the top tube tank. It really seemed like there had to be a better way to fill. Is that what you used on your build Clotho? weld on or epoxy on? anyways thanks for the link!
Rotor
Old 07-15-2009, 12:00 AM
Clotho's Avatar
Brake bleeders?
I used JB Weld to seal the holes in my tank then I used a tank sealant process to seal it. I used a bung and cap similar to the one I linked to fill with. To vent it I drilled a hole in the cap, attached a brass fitting and ran a hose like you see on motocross bikes.
Old 07-15-2009, 05:05 AM
RedB66's Avatar
RedB66 RedB66 is offline
Twisted Choppers offers a small vented cap and bung that only requires a 1.125 inch hole (Just large enough for a gas pump nozzle).
</title> </head> <body bgcolor="black" topmargin="0" bottommargin="0"> <div align="center"> <table width="64" border="0" cellspacing="0" cellpadding="0"> <tr> <td><img src="images/header.jpg" alt="" height="89" width="770" border="0"></td> </tr> <tr>
MOTORBICYCLING.COM STICKERS
Old 07-15-2009, 10:57 AM
on the fuel fill bungs you guys posted, would it be best to weld, braze or epoxy in? Thanks for the responses!
Rotor
Old 07-15-2009, 08:05 PM
Clotho's Avatar
Welding by a professional is always best but you can kiss the paint goodbye. I epoxied mine. If you make sure the surfaces are clean epoxy can be an incredibly strong bond. If you apply the JBWeld (Epoxy) to the surfaces and then work them a bit with a wire brush the bond will be even stronger.
Old 07-31-2010, 04:14 PM
pinocho bikes pinocho bikes is offline
idea or solution brakes rear for felt shief bikes 4 strok gas motor
Old 07-31-2010, 04:23 PM
grinNbarritt's Avatar
grinNbarritt grinNbarritt is offline
If you look up Terry Blows felt twin build thread, he has links to the youtubes he did on the whole felt tank process.
