Old 07-14-2009, 06:08 PM
ut1205 ut1205 is offline
Default Vibrations in Friction Drive Bikes
First of all I tried the "Search" and found very little on friction drive kits. Maybe I just haven't learned how to properly use it. I have a new bike on the way for some motor kit. I have read what seems like hundreds of post here that complain about vibrations that make parts fall off the bike and require retighting of connectors often. I want my bike to be one that I can ride and not have to work on constantly so I am leaning toward a friction drive system with a Honda 4 stroke engine. This seems like a simple system with very few parts that would be easy to replace. I do not ride in the rain so that is not an issue for me. My question for the owners of friction drive owners is how much vibration do you get with the friction drive system. Anybody want to talk me out of friction dirve?
Old 07-14-2009, 09:14 PM
bbb's Avatar
bbb bbb is offline
Default Re: Vibrations in Friction Drive Bikes
No vibration with my Dimension Edge Mitsubishi TL43-E system...had a small learning curve on roller to tire depth...works flawlessly. They talked me into the 2-stroke and it is quiet with no smoke or smell.
Old 07-15-2009, 09:49 AM
What did you find the right tire depth to be for your bike?
Old 07-15-2009, 11:36 PM
bbb's Avatar
bbb bbb is offline
Lower the tire down to 5-10 lbs and engage, then fill to max-50lbs, on mine.
Took a few tries until i no longer saw black dust (tire) all over the rear of the bike.
