Old 07-14-2009, 08:42 AM
njbshark njbshark is offline
Default CDI Fried after 5 runs?
Is it really possible to not have a spark after 5-6 runs. I have checked all the wiring and still don't have a spark. I am really annoyed. I finally got it all tuned right and now this. Any ideas?
Old 07-14-2009, 10:24 AM
Finfan's Avatar
Finfan Finfan is offline
Default Re: CDI Fried after 5 runs?
The spark problem starts at the magneto and ends at the plug. Check to be sure that the wiring connections are good and that the kill switch isn't shorted. If those are OK then make sure your plug wire is contacting the CDI. From there you can just start swapping parts to see if it fixes the problem.
-and-
I'm not lost, I'm exploring!
Old 07-14-2009, 12:20 PM
All the connections are good I sodered them all to start when I was building...kill switch is not hooked up. I am annoyed and ordered new parts. It just sucks that the motor is new and already crapping out.
The CDI to spark plug and connector looks to be a really bad design.
Old 07-14-2009, 01:04 PM
Cabinfever1977's Avatar
if you have a warranty they might replace your cdi. how do you know its the cdi and not something else like the mag or a loose plug wire,did you use a tester.
Old 07-14-2009, 01:51 PM
Well.... The warrenty is a funny thing. I was shipped a dented gas tank with a hole in it and it was never replaced.. That company sucks. They will remain nameless as they advertise of this site
The plug wire just pulled out so I reconnected it and make sure all those connections were tight. My best guess it that the cdi is shot. I think i placed it too close to the exhaust.
It has been harder and harder to start for the past 2 days but has only really run 6 times.
Old 07-14-2009, 05:59 PM
well. Rewired all the connections. All new wires from start to end. It works now.
However, The spark plug wiggles loose. Any hints on that?
Thanks for all you help.
Old 07-14-2009, 06:53 PM
Clotho's Avatar
Clotho Clotho is offline
This is probably what caused your problem. The plug wire screws into the CDI unit. If it is loose I cut a bit off with some wire cutters and I apply some silicone cement on the sides before screwing it back in. Make sure you don't get the silicone on the end where it makes contact.
It is pretty easy to dislodge this while working on the bike. I usually replace my wire with a longer automotive one and place the CDI box under the motor where it is out of the way.
__________________________________
Old 07-14-2009, 09:17 PM
I realized that too. I have run all the wires and throttle and clutch cable inside the frame for a really clean look. However, when it stopped working I had to pull alot of those out. It was just a pain but a learning experience. [IMG][/IMG]
Old 07-15-2009, 01:53 AM
Clotho's Avatar
Great looking bike!
It seems from the picture that the plug wire looks a bit short and as such will probably pull out again. I would try to find something a bit longer.
Old 07-15-2009, 05:37 AM
Bikeguy Joe's Avatar
Any 7mm wire will work.
