Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > High Performance Bicycle Engine Tips
High Performance Bicycle Engine Tips We all want our bicycle engines to push our bikes faster. Get exclusive engine modification tips and suggestions from us.
Old 07-12-2009, 02:59 PM
bodydropped bodydropped is offline
Default oh darn engine mods led to more issues..lol
let me start by saying i have built 2 of these little bikes both with the same black stallion engine kit.
they run great. on my bike after 30 miles of riding in 3 days a rear mount stud sheared off in the block.so i figured it was a fine time to modifiy it since it was off the frame for the new stud repair.
i notched the piston,ported the intake tube and the intake port aswell as the exaust and exaust pipe.
i fiddled with the carb a bit too.
i noticed an imediate differnce in the bikes performance it accelerated so smooth and was a ton more responsive.i was happy but sometimes i look for more so i was like let me find the top speed hahaha
as soon as i worked out the fule foaming issue well kinda its still an issue i went for it.i managed to hit 34 mph going slightly uphill and it was still climbing with a ton of vibration and bang! the front mount stud sheared of in the front frame mount lolol i cant win.
the extreme vibration was caused by my solid mount i made in the rear for the repair no fault to the motor or the bike but it was my own. i would like to add the the other bike is going strong and hit 38mph smoothly with little or no vibration and all i did to that one was tinkered with the carb it still does not pull as hard as mine though.
any ideas in the studs? does anyone know if ARP makes studs or bolts this small anyone else have this issue? oh and i know i should not go this fast on the street i was in a closed area and i am more comfortable at 25-27 mph but i wanted to see the max just to see.
Old 07-12-2009, 03:07 PM
skyliner skyliner is offline
Default Re: oh darn engine mods led to more issues..lol
yea man i can relate ive built 27 bikes for other people and ive been riding mine for about 2 years now and let me tell you there no more stock mounts on there and im hitting 38.8mph on a regular ive got a dax 80cc with cns carb and sbp expansion chamber fastest ive gone was 40 according to my gps but whos to say thats right now i have a speedometor and goin strong runnin 35:1 oil ratio but all is well so good luck and dont let the man get you down lol keep truckin or bikin whatever
if you dont see smoke your doin somthing wrong fly low beat the radar
04 shcwinn 80cc dax sbp camber cns carb boost bottle k&n filter 36 tooth 40mph (gps tested) havin fun and smokin scooters
Old 07-12-2009, 03:55 PM
reg454's Avatar
reg454 reg454 is offline
I would retap the mounts a little bigger for american standards then get some good alen bolts that way you will get a good tight mount with no worry about breakage
Old 07-12-2009, 08:41 PM
i tried removing the stud that snapped in the rear and no luck at all, lock tite has it in really snug.
i used a small drill bit and extractor and the extractor broke off inside the hole...doh!
its ok though im ordering another kit for a diffrent bike so i will leave this one as my goof off bike i guess right now i have the motor on and snug but i dont trust it yet.with the new kit i will need a source for good bolts or do i have to retap the new motor aswell to use better quality bolts?
Old 07-12-2009, 10:09 PM
reg454's Avatar
A hardware store should have the bolts that are the same size as the stock ones, or you can go a little thicker diameter just to be sure and if you have a tap set that you can do it with. Also if you go with the stock size make sure you get them grade 7 or better.
Old 07-13-2009, 02:40 AM
Junster's Avatar
Junster Junster is offline
The first thing I do when I order a motor is goto the SBP site and order a stud kit, fuel petcock, teflon clutch cable. With the shipping it's about 28 bucks. Will save you a ton of grief. I've checked on the price of buying all these bolts at a hardware and the cost is about the same if you can find all the right ones. The fuel petcock they carry is a high quality chrome ball valve that will never leak. The teflon clutch cable pulls easier and is way stronger.
Sick Bike Parts
Put something FUN between your legs..
Old 07-13-2009, 07:33 AM
Bikeguy Joe's Avatar
Just buy good M6X1.0 allthread and replace the stock studs....easy cheap, effective.
Old 07-13-2009, 07:34 AM
Or get the whole kit from SBP.
Old 07-13-2009, 09:51 AM
BrettMavriK's Avatar
BrettMavriK BrettMavriK is offline
What is a Black Stallion Engine Kit?
I searched the forum to no avail.
http://s90.photobucket.com/albums/k2...h_IMG00208.jpg
My Production Bobber Build Up
'BrettMavriK
"Everything Is Possible...If You Can See Beyond The Invisible"
Old 07-13-2009, 10:18 AM
dvddtz's Avatar
dvddtz dvddtz is offline
Hey Brett,look on the right side of this page,4th one down.
