Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 07-12-2009, 02:46 PM
impression impression is offline
Default crank axle help please
well, i bought the shift kit and found out that it came with an axle that i believ goes between the crank arms of the pedals
it goes pedal > crank arm > crank ( within the bike frame ) crank arm > pedal
that middle crank axle is what i need to change, but i have no idea what to do in going about changing it.
I've looked on the net and the video help guide sites for bikes, but alas i probably cant think of the proper name for this part and that's why im not finding what i'm looking for.
any help would be greatly appreciated
Old 07-12-2009, 06:17 PM
Cabinfever1977's Avatar
Default Re: crank axle help please
you need to look up how to remove 3-piece cranks:
http://www.danscomp.com/install/Pove...nk_Install.pdf
Bicycle Repair: removing cranks, 3 piece cranks, bottom bracket shell
Free advice on how to fix your bicycle: HOW TO REPAIR A 3 PIECE AND SEALED BOTTOM BRACKET
i think the long middle part is called a spindle.
Old 07-13-2009, 12:17 PM
Ghost0's Avatar
Ghost0 Ghost0 is offline
Here is another tutorial.
How To Overhaul A Bottom Bracket - Bicycle Tutor
Design is easy, execution the hard part.
www.sickbikeparts.com
Old 07-13-2009, 05:22 PM
ghost0 with the crank axle, the one that was supplied with the kit, is that included as it will definately give me clearance for the chains to run where they need to path through ?
I've just been doing this shift kit/engine setup on my 'better' bike for about 2-3 months now in ym spare time and this is where i've been held up for some time. I'll see if i can get some pictures of my progress and my problems and see if i can upload for some fresh eyes
Old 07-13-2009, 05:25 PM
Ghost0's Avatar
OK I am a little confused, you say you have a shift kit but you are asking if the spindle is included, yes it is included.
Old 07-13-2009, 11:21 PM
sorry, it was about 3am when i wrote that.
what i'm asking is this.
Will the included spindle/axle give me the clearances i need to run the chains through where they need to go
Old 07-13-2009, 11:22 PM
Ghost0's Avatar
It should, that is why we include it. It is longer than normal spindles.
