Old 05-11-2008, 07:31 PM
Juls Juls is offline
Default Re: new, just bought kit, looks like motor dont fit!
Originally Posted by Bikeguy Joe View Post
A "comfort bike"? I am not up on all the modern terminology....my boss yelled at me because I called his 800 dollar road bike a "10 speed".
He said "You obviously don't know ANYTHING about bikes." (yes, he's a leg shaver/spandex elitist who rides a couple dozen miles a year)
Anyhow, once you fit a bicycle motor to a bike, it becomes a motorized bicycle...and I do know a thing or two about those.
Good! Because we haven't got it put together yet and I am sure we will be needing more help!
Old 05-11-2008, 08:21 PM
sisdavid sisdavid is offline
You do not need to drill through fram if you use a muffler bracket to go around wider tube.
Old 05-15-2008, 08:16 PM
Now we are having a problem, when we mount the engine, the muffler doesn't quite clear the pedal. We can't tilt the motor enough to get the clearance. because it is a tight fit. We are thinking of banging the muffler in a bit.
Old 05-15-2008, 08:19 PM
paul's Avatar
paul paul is offline
Administrator
i had the same problem with mine so i took the pedal off and used a pipe and put that on the crank and bent it out just enough so i the pedals would clear the exhaust
Old 05-15-2008, 08:24 PM
Thanks we might try something like that. We are having the argument of dent the muffler in a bit or try to knock the pedal out a bit. I vote for knock the pedal out a bit!
Old 05-15-2008, 09:13 PM
nogoodnic's Avatar
nogoodnic nogoodnic is offline
Welcome to the group Juls. Looks like your in good hands already. Look forward to seeing your bikes...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
Old 05-15-2008, 09:55 PM
Can Harm Hen's Avatar
Can Harm Hen Can Harm Hen is offline
I tried denting my pipe, too. There's some kind of structure underneath, so it only dented a few millimeters. Not enough. I had to heat and bend the pipe. Bending the cranks also sounds like a good idea.
-Herman
"Do not take life too seriously. You will never get out of it alive." -Elbert Hubbard
MotorBicycling.com
