Re: engine won't start, clutch problems??
make sure gas petcock lever is in line with gas line(on position),push primer twice,then with clutch pulled in and choke up/closed ,peddal up to 10mph and release clutch and keep peddaling then pull in clutch and let idle,while giving some throttle.if engine starts, after 1 minuite push choke down/open.
if engine didnt start repeat this again.if still not starting check all wiring.
during hot temeratures the choke may need to be half closed or fully down to start engine.
when not using bike turn off gastank petcock.
