View Poll Results: sprocket size makes difference in speed or torque?
smaller sprocket = higher speed 3 75.00%
bigger sprocket = lower speed 0 0%
smaller sprocket = more torque 0 0%
bigger sprocket = less torque 1 25.00%
Multiple Choice Poll. Voters: 4. You may not vote on this poll
Old 07-09-2009, 07:49 PM
fauxmaster's Avatar
fauxmaster fauxmaster is offline
Default rear sprocket size?
im building a trike, it is a 3 speed to the rear stock. the cross shaft that has the 3 speed sprocket will only let me clear a 6 inch max sprocket which will be mounted to directly to the shaft and not the bike spokes... does anyone have any ideas as to what will happen with such a small sprocket mounted to the back, will i be traveling faster but slow to get there or slower but a **** of a lot of torque?
Old 07-09-2009, 08:01 PM
Cabinfever1977's Avatar
Default Re: rear sprocket size?
you have your poll wrong. you have the torque backwards.
the correct answer is this:
smaller sprocket= less torque/slower acceleration/faster top speed
larger sprocket= more torque/faster acceleration/slower top speed
6" is around the size of a 36t sprocket i think
you will be traveling faster but slow when starting out , with less torque.
Old 07-09-2009, 08:55 PM
matt167 matt167 is offline
a pic to show your issue would be very helpful.. the bigger the sprocket, the more torque you will have, but a reduced top speed.. smaller will be opposite..
Old 07-09-2009, 09:02 PM
also it would help if we knew what engine you are using.
if the engine is atleast 1.6hp+ and you can fit a 36t sprocket on there,you should be fine. you might not go up steep hills or take off fast but once you get going, you should be able to fly down the road at some good speeds.
Old 07-09-2009, 09:40 PM
got to remember, he has double the rolling force.. 2 rear wheels, full axle and a bit heavier than a bike
Old 07-09-2009, 10:09 PM
igore igore is offline
question
I have a 3 hp 4stroke engine with a 10 tooth drive sprocket driving a 52 tooth wheel sprocket is that about right???
thanks
Old 07-09-2009, 11:38 PM
Banned
Good grief!!!
Jim
Old 07-10-2009, 07:06 AM
just reread my post... geared tall unless it's got 30" tires.... on a China, it would be a hill climber with a top speed of about 20, but a 3hp 4 stroke has enough torque for the hills, and really 40 tooth would be more than sufficent
Old 07-10-2009, 07:59 AM
Bikeguy Joe's Avatar
Originally Posted by Creative Engineering View Post
Good grief!!!
Jim
FO'SHO'!!!
Old 07-10-2009, 08:00 AM
Don't forget the china engine has an internal reduction.
