Old 07-08-2009, 02:35 PM
James91 James91 is offline
Default spark plug cap spring
I removed the cap off of my spark plug today after noticing that it had moved after a very short ride and when i looked inside it i noticed a very small spring on the inside of the cap that was loose and fell out. Its about this big ===== lol thanks for the help
Old 07-08-2009, 03:53 PM
Ghost0's Avatar
Ghost0 Ghost0 is offline
Default Re: spark plug cap spring
I would get a new plug wire and plug. Just so these things don't happen in the future.
Design is easy, execution the hard part.
www.sickbikeparts.com
Old 07-08-2009, 04:43 PM
What exactly is the purpose for the spring
Old 07-08-2009, 05:28 PM
I actually just found out that there was a piece of the spark plug cap was still on the spark plug. Does this mean something is broken?
Old 07-08-2009, 05:52 PM
2door's Avatar
2door 2door is offline
James,
Like Pablo said. You need a new spark plug and go with a good automotive style plug boot. I'm sort of anal about things like that so I solder the wire to the terminal that goes inside the boot. Of course that means using metallic core wire. You can't solder resistance wire. Hope this helps.
Old 07-08-2009, 08:38 PM
I'm thinking about just buying a new cdi because the screw is out and does not want to stay in. Does anyone know where to get a good cdi that wont have as many problems?
Old 07-08-2009, 10:00 PM
reg454's Avatar
reg454 reg454 is offline
The wire thats comes out of the cdi to the spark plug just unscrews you will not have to get a new cdi. just unscrew the wire from it, and the wire unscrews from the cap the goes onto the spark plug as well. let me find a post real quick.
This is a post by the Norman about sparkplug boot tear down.
http://motorbicycling.com/f34/sparkp...down-5899.html
