Old 07-04-2009, 06:25 PM
dag_29307's Avatar
dag_29307 dag_29307 is offline
Default broken throttle Quick fix
I bought the 80cc motor kit and within two weeks the throttle was busted! (stupid plastic)
First thing I did was to use hot glue (three applications) to support the back of that little tab and it worked for a while. I wanted something more permanent so I went to the auto parts store and started to look into epoxies but I found the stuff called "Quick Steel" looks like "Mighty Putty" only gray and black I used a little bit and made a backing where the hot glue was. Once it dries you just sand it to fit into the track then reinstall good as new.
Hope it Helps. I am also a proud member of the 20 MPH. club
Old 07-04-2009, 10:14 PM
unior's Avatar
unior unior is offline
Default Re: broken throttle Quick fix
That sounds like the same thing as JB stick weld. I never tried it on plastic though its good to know it will bond.
Old 07-05-2009, 12:00 AM
will 3501 will 3501 is offline
use a brake lever i tried fixing that way didnt last but mine was totally wasted. I used a brake lever but u got to find one that fits the cable end . Or go to a cycle shop or scooter accessories store and get a little trigger lever one.
Chill Will Fear no Evil
Old 07-05-2009, 03:39 PM
matt167 matt167 is offline
quick steels good, kinda messy tho. too soft to work with.. I use very simmilar stuff from carquest.. same thing just not as messy
