Old 07-03-2009, 04:21 PM
reg454's Avatar
reg454 reg454 is offline
Default Magneto rewinding
After I was looking at my magneto and finding out that it is shorted out I am going to rewind it here in a couple days and see if it fixes it. This way I can get rid of the white wire and know what gauge wire is on it, I can get id of the ground that is soldered on the mag itself and put a coat of epoxy thin) on each winding that way I will know for sure that it wont go again. I am going to use a little thicker gauge wire that what is on their now and I will write back to let you know how it goes.
By the way I am going to get 2 new mag's from thatsdax here in a week also a new cdi too. This is just a test to see if manually winding will work.
Old 07-03-2009, 05:14 PM
reg454's Avatar
Default Re: Magneto rewinding
I just totally ripped apart my magneto and what I found was this the bulk of the thin gauge wire is the blue wire connected to the ground and the white wire. The first part of the windings like 5 layers (a layer of tape separate them) is the white wire a thicker gauge than the blue it is connected to the ground and the blue wire. So both the blue and white have a common ground. The rest of the layers (no separation of the layers) blue is just spun anyway the person who did it felt like.
Pictures below
White wire
You can kind of see where they are all connected in this pic
You can see the separation of the layers of the wire here and the blue windings most of it taking off (note their is a layer of tape between the white and blue layers).
I am going to rewind the coil and separate the grounds between the 2 that way their will be loss of power when I want to hook up light system to it. Their will be just 4 wires coming out of the magneto cover instead of 3. I will also get rid of the ground soldered to the magneto.
Going to radio shack now to pick up some wire.
empty magneto
Old 07-03-2009, 05:26 PM
Goat Herder's Avatar
Gutter Rider
Did you count the wraps winds very important!
Old 07-03-2009, 05:56 PM
freewheeling frank freewheeling frank is offline
really interested to see how this comes out keep us posted
Old 07-03-2009, 08:40 PM
Cabinfever1977's Avatar
i cant wait either,i hope i never have to do that
Old 07-03-2009, 10:16 PM
Banned
I still think a "Pro Shop" is a good idea guys...Paul, Joe, David, Norman, Barron, Tom...what do you think?
Jim
Old 07-03-2009, 10:58 PM
MelMartinez's Avatar
MelMartinez MelMartinez is offline
Dealer in Mexico
No wonder my lamp wonŽt turn on !!! Furthermore, today that I connected the white wire to a 6 volts lamp, the engine wonŽt start. There was no spark at all.
Can someone tell me where can I get the 6 volts out from the magneto to turn on a lamp?
Thanks.
See You in the Road !!!
Old 07-03-2009, 11:50 PM
Banned
Thanks.
Mel...
Wattage is the important factor...Volts are only one part of the equation. Amps X volts = Watts!
If the filament in the lamp you have chosen requires more amperage to light than the magneto puts out...the lamp will not light, and neither will the spark plug.
Jim
Old 07-04-2009, 12:01 AM
Dealer in Mexico
Thanks Jim, IŽve figured out: We only have 3 watts from the white wire... and my lamp calls for 50 watts... piece of cake.
IŽll install an AC/DC rectifier and an small battery. IŽll see if I can have some charge out of it... and keep the spark in the plug.
Old 07-04-2009, 12:23 AM
reg454's Avatar
Originally Posted by Creative Engineering View Post
Mel...
Jim
along of what Manic has siad from what I have noticed from taking apart the magneto if you take too much voltage from the blue wire you will kill the white wire. both the blue wire and the white wire are hooked into the same ground. if you were to hook it uo the other way you would be getting 5x times the voltage/ amperage than you would have. You would be going from a 22 gauge to a 30 gauge wire.
I hooked up my new magneto and I am getting the correct amount of voltage but I noticed my cdi is blown. I noticed back fire the other day, it ran but only untill I let it sit for a couple hours then bang no go.
