Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Wheels, Brakes and Suspension
Wheels, Brakes and Suspension Keep your motorized bicycle on the road with suspensions, rims, tires and disk, drum and caliper brakes
Old 06-30-2009, 09:53 PM
RedB66's Avatar
RedB66 RedB66 is offline
Default Disc Brake Adapter
Disc brakes for front forks. I came across this site that offers an adapter for use on front forks (any). They use a free wheel rim on the front turned around so that the disc brake adapter threads on and then there is a seperate bracket that holds the brake caliper. Pretty neat idea!! The bracket for forks without caliper tabs is near the bottom of the page.
Brakes
MOTORBICYCLING.COM STICKERS
Old 06-30-2009, 10:03 PM
bbb's Avatar
bbb bbb is offline
Default Re: Disc Brake Adapter
I have dealt with that supplier quite a bit being as we are both north of the border and he has been great to work with.
Old 06-30-2009, 10:27 PM
Dave31's Avatar
Dave31 Dave31 is offline
Thanks for the link, I am looking to add front disc someday in the future.
Old 07-01-2009, 04:55 PM
Goat Herder's Avatar
Gutter Rider
Thats very cool there a lot of folks that need better brakes LOL Thanks for the link!
Old 07-01-2009, 05:35 PM
2door's Avatar
2door 2door is offline
Good find, Red,
They have some great looking things. My new Jag project is crying for either disc or drum brakes, especially in the front. Thanks.
Old 08-29-2009, 04:38 PM
GeneFiorot GeneFiorot is offline
Banned
I have read that if you loosen your axle nuts and your front wheel can drop out of the fork on its own you should never equip that fork with a disc brake as the action of the braking pulls the axle out of the fork.
Old 08-29-2009, 07:19 PM
RedB66's Avatar
The bracket is independent from the brake. I don't really understand your point here. "If you loosen your axle nuts and the front wheel can drop out" I would think that part of the installation requires you to tighten the nuts up after you mount the bracket.
Old 08-29-2009, 08:17 PM
Banned
MY point was on of a safety issue. If you have the type of fork that when you loosen your axle bolts and you lift the wheel off the ground and the wheel simply drops out of the fork it is not recommended to use a disc brake with this type of fork. The reason is the torque applied to the disc when braking tends to pull the axle out of the slot. I have no knowledge of adapters simply what I have stated for others to research as I have done regarding adding disc brakes and the limitations of certain forks notwithstanding using adapters.
Old 08-29-2009, 10:11 PM
Kevlarr's Avatar
Kevlarr Kevlarr is offline
I can't see how that would happen. The torque applied at the disk would be no different then the torque applied by caliper brakes. If your axle nuts are tightened properly there shouldn't be any problem.
Old 08-29-2009, 11:15 PM
Banned
This was not the first place I read this I am looking for the original comments....
A correctly secured quick release is unlikely to be ejected from the dropout in normal use where rim brakes are in use, although recently there has been some evidence, notably from James Annan, a British scientist working in Japan, suggesting that the moments in disc brake systems can cause quick-release front wheels to be ejected past the lawyer tabs. A small number of serious crashes have been attributed to this cause. This is controversial, and the fork manufacturers have not admitted a fault, although there is some evidence that they may accept the principle, and advice on checking quick release tension has been strengthened. [3][4] A complete solution to ejection risk would involve mounting the front disc brake caliper in front of the fork blade rather than behind, as the reaction force on the disc would then be into, rather than out of, the fork-end. However, this would involve major retooling by fork and brake manufacturers, though British manufacturer Cotic has placed the disc caliper mounts on the front of the right fork blade on its Roadhog fork. This allows standard brakes to be used, and also makes it easier to mount mudguards.
