Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 06-29-2009, 06:00 PM
biggoolies biggoolies is offline
Default new throttle cable for staton rs 35
Hi need a new 65 inch cable for my staton robin subaru 35. 65 inch. Any ideas where I can search for one locally rather than get one from staton?
thanks,
Darcy
Old 06-29-2009, 06:28 PM
reg454's Avatar
reg454 reg454 is offline
Default Re: new throttle cable for staton rs 35
thanks,
Darcy
What is wrond with your old one? Did it stretch out, if it did I made made a bracket that anyone with a drill press, some allen bolts, and washers also a piece of 1/16" thick 5"long x 3" wide can make. Their is a link below.
Old 06-29-2009, 07:53 PM
It seems to work fine when I take the cable out and move it back and forth. Also the throttle lever works fine, but when I put it all together, it is not smooth moving and takes a little force. Maybe a bit rusted in the cable?
Darcy
Old 06-30-2009, 10:54 AM
happyvalley's Avatar
happyvalley happyvalley is offline
You can lube cables by holding by one end running a few drops of oil down into them.
If it works smoothly off the bike though it might be something else like, routing, in the
lever itself, at the carb connection. Does the lever and butterfly on the carb work smoothly
with no cable?
