Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 06-28-2009, 08:57 PM
atvaholic atvaholic is offline
Default The maiden voyage...not so good
hello, i've been lurking in these forums a while, and love it! Great info on here. I decided to purchase one of the "80" CC kits from China. Im not very mechanical so I had a friend do the install for me. He got everything done, and the bike was running great at his place. I took it home and earlier this evening went for a ride. About a mile from home I was going slow (about 15mph) and the engine just died. I thought maybe I was out of gas so I peddled home. I tried to start a few times but it would not. As i said im not much of a mechanic but my friend left for a few days. I had a look at all connections and they seem ok. I pulled the plug, tried to look for spark, but could not see any. (It was hard to check as I had to kick the bike to try and turn it. Any suggestions on what else I can check?
Old 06-28-2009, 09:45 PM
reg454's Avatar
reg454 reg454 is offline
Default Re: The maiden voyage...not so good
If you are not getting any spark try this first unhook the kill switch them try starting the bike. The stock kill switch's are known for shorting out. If the bike starts you can just hook up a cheap toggle switch, to kill the motor without a kill switch you can put full choke on, or stop and release the clutch to kill the motor.
Old 06-28-2009, 09:46 PM
Thanks for the quick reply! Whats the best way to unhook it?
Old 06-28-2009, 09:53 PM
reg454's Avatar
look where all the wires hook together depending on how they are hooked up you will have to separate them. Only do one batch at a time the blue wire group then the white wire group because you do not want to mix up the wires. If you have electrical tape that should be fine to cover the wires back up.
Old 06-29-2009, 08:06 AM
Bikeguy Joe's Avatar
I would wait until you friend gets back before removing or cutting any wires if you don't know what you are doing.
Old 06-29-2009, 08:43 AM
reg454's Avatar
That is true Bikeguy Joe
Old 06-29-2009, 11:32 AM
Hey thanks for the tip...I took apart the switch and saw the black and yellow wire were touching! I seperated them and I now have spark! But the motor still wont start? I smell gas, I wonder if its flooded? I tried a new plug in case the old was fouled. Same thing. The motor turns over but does not even cough or sputter.
Old 06-29-2009, 11:52 AM
TerrontheSnake's Avatar
TerrontheSnake TerrontheSnake is offline
Don't release the clutch until your up to speed better, put the choke on half way before taking off. Check your exhaust and intake gaskets, make sure all nuts and bolts are still tight.
Old 06-29-2009, 01:16 PM
Thanks!! It was the choke! It starts up when at half position. Now, lets see about tuning this baby!
Old 06-29-2009, 01:51 PM
I had to tighten down the lil nut if you take off the air cleaner you can see it. I would get to haulin down the road and couldn't figure out why all of a sudden it would just die. My choke was so loose the Vibration would close the choke on me. Might do that before you get to much farther to avoid the same prob. Congrats on the ride and good luck with all your future MB endeavors. Beware, if this is your first MB it won't be your last!
