Old 06-28-2009, 04:35 PM
HT2005 HT2005 is offline
Default Clutch problem
I recently bought a 66cc engine kit and installed it. The problem is that no matter how I adjust the star nut, the clutch either slips while engaged or catches while disengaged. Actually, as of right now it does both. I use the "locking" clutch lever. How can I make it so I can use the same clutch lever, have it fully functional, and fix the clutch so it tightly engages when I want and it disengages when in the locked position. I don't think it's the cable because it is as tight as it's going to get; there is no slack in it. Please help.
Old 06-28-2009, 05:38 PM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Clutch problem
Are your pucks free floating? (tons of threads on this)
You MAY need to tighten up your internal main spring (posts on this as well)
Do a search.......
Old 06-28-2009, 05:55 PM
reg454's Avatar
reg454 reg454 is offline
Norman did a post on how to tighten the inner clutch spring thats is probably what you need to do because of your symptoms.
Their is a link under this to a post that I did on how to do it too
Old 06-28-2009, 07:39 PM
I just tightened the spring and almost had everything back together. I was just doing some last minute adjusting of the star nut when the clutch cable snapped at the handle. Now I need to loosen the spring and install my last cable to see how that works. While adjusting the spring, I couldn't even tell anything was happening.
Old 06-28-2009, 07:52 PM
reg454's Avatar
you wont notice untill to try to engage the clutch plus it might be a little harder to pull the clutch in. Where did the cable snap at? I don't use the stock cable I just go and get a brake cable from a bike shop they are better and they are cheap too.
Old 06-28-2009, 08:46 PM
The cable snapped at the keg-shaped thing that connnects to the clutch lever (cheap piece of crap). I swapped it out for a teflon coated cable from Sick Bike Parts. After the other one snapped, I unscrewed the spring about a turn and a quarter. After installing everything again I think I will have to make a quarter to half turn tighter adjustment tomorrow. It's getting dark here now and don't want to annoy the neighbors with testing.
Old 06-28-2009, 08:59 PM
reg454's Avatar
OK it's looking like your getting close to tuning in the clutch now.
Old 07-04-2009, 03:54 PM
TheE TheE is offline
I sorta have this problem too. On mine it just doesn't disengage fully. I think it's because when the handlebar lever is in the "locked" position, it is not pulling the clutch arm in far enough. I've adjusted the little flower nut and it improved a bit...wish they had a locking mechanism which pushes the lever in further though.
Old 07-04-2009, 05:22 PM
reg454's Avatar
I do not use the locking handle I use an old brake lever. My clutch disengages when the lever is half way pulled. When you tighten the inner clutch spring you will get more play in the clutch because it pushes the pin out more so the clutch rod has more movement, that is what I noticed when I tightened mine. But you will have to readjust the flower nut with any tightening or loosening of the spring. If and when you do it loosen the flower nut before so it is easier to do the fix.
Old 07-04-2009, 11:35 PM
unior's Avatar
unior unior is offline
I have a question. How are you supposed to know how tight to go when tightening the inner spring? One revolution of the rear wheel? A half turn? Whats a good starting point?
TIA
unior
