Old 06-26-2009, 07:56 PM
TheE TheE is offline
Default "Coughing" Engine
I just finished building my first motorized bicycle and am having a great time with it. I'm using a Limited Edition 49cc motor from Powerking. Great stuff!
Anywho, I noticed the engine tends to "cough" at low speeds, wherin it basically snags and I feel the jerk. This dissappears as I open up the throttle. Now I was replacing the cheapo Chinese spark plug with a better one today, and I noticed that the spark contacts were black. I've been reading the forums a bit, and apparently, that's not right.
So I think I might be having a fuel mixture issue, which would also explain why the engine is "coughing" at low throttle. However, I'm also using a 16:1 oil fuel ratio (that's what the manufacturer reccomends for early break-in), so I was thinking mabye that was the problem.
So I put the question out to the experts here: Is the coughing normal, or is there something I should be doing to smooth it out? It isn't really that bad, and it lessens as the engine warms up, but if I could reduce it that would be cool.
Old 06-26-2009, 09:32 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: "Coughing" Engine
What is the spark plug gaped at? try 0.020 gap.
you might go to a mix of 20 to 1 then go to 32 to1 the more oil the harder it is to fire off the mix.
stock carb setting are
#2 notch on the needle from the top of the needle or the fat end. main jet dia is 0.70mm with it missing at low rpm it might be a little rich. this slight miss should go away as it get broken in and you go to a mix of less oil to gas.
The needle measures about 0.078 up by the notches and tapers to about 0.068 at the pointed end.
Float setting, with the carb upside down and the float bowl off the float should set about level on the tangs.
Norman
norms-iron-works.tripod.com
Old 06-26-2009, 11:01 PM
Shadeslay's Avatar
Shadeslay Shadeslay is offline
I agree with Norman,
Running that rich they run rough. If your plug is black, you'll want to raise your needle clip a notch or two, which may help. 16:1 is pretty rich even using cheap oil, you could get away with 20:1 and still be on the safe side.
Sun Tzu: To secure ourselves against defeat lies in our own hands, but the opportunity of defeating the enemy is provided by the enemy himself.
Old 06-26-2009, 11:33 PM
Ok, I'll try using 20:1 on my next fill-up. I'm using pretty high-quality synthetic oil, so I guess it'll do fine. If it really comes down to it, I'll pull the carb apart...I'd like to avoid that if possible.
Thanks for the advice =D
Old 06-27-2009, 08:37 AM
Bikeguy Joe's Avatar
I would go to 24:1 now. 20:1 is still way too much oil, especially with synthetic.
Old 06-27-2009, 05:44 PM
Cabinfever1977's Avatar
i would use reg 2-stroke oil for breakin and then synthetic after.
Old 06-28-2009, 04:10 PM
bike916 bike916 is offline
Hello all. First post. I just did a conversion with a pk80. Mine has the same issues as the OP. It coughs or the way I put it...it seems like it has some cams in the engine with a lopey low end, but top end opens up nicely. I'm using chevron 2 cycle oil with a 16:1 ratio as well. What is the needle everyone talks about? Which spark plug should I upgrade to? Thanks guys and I'm glad to be here.
Old 06-28-2009, 06:14 PM
Go to 24:1 for one thing, 16:1 is just too much oil. You can't tune an engine that is running on the wrong mix. (I know what the "instructions" say).
The needle we refer to is the slide needle located in the slide, inside the carb.
Old 06-29-2009, 02:14 AM
After the right mixture and a better plug, hopefully it clears up. Thanks again.
Old 06-29-2009, 06:51 AM
Keep us posted.
