Old 06-24-2009, 11:42 PM
Mikey DEEEE Mikey DEEEE is offline
Default bike going slower
my bike seems to be getting slower after break in than faster, any ideas??????
Old 06-25-2009, 12:11 AM
Finfan's Avatar
Finfan Finfan is offline
Default Re: bike going slower
Air filter is dirty thus restricting air flow.
Crud in carb or clogged up fuel filter.
Throttle cable is stretching. (I'm reaching a bit on that one.)
You're gaining a lot of weight by not pedaling.
How are those?
-and-
I'm not lost, I'm exploring!
Old 06-25-2009, 12:17 AM
i like the weight one ha ha ha ha ha ha ha ha ha ha how do i adjust the throttle cable?
Old 06-25-2009, 12:23 AM
reg454's Avatar
reg454 reg454 is offline
i made this because of the stretch in the throttle cable.
watch the link to the vid it shows you what the movement is like.
http://motorbicycling.com/f3/throttl...mbly-9076.html
Old 06-25-2009, 12:30 AM
Cabinfever1977's Avatar
airfilter,sparkplug,and in gastank filter may be dirty.
Old 06-25-2009, 12:48 AM
How do i clean the spark plug and air filter, im very dumb when it cones to these things
Old 06-25-2009, 12:59 AM
Emerica's Avatar
Emerica Emerica is offline
check all of your bolts over, make sure it's still mounted tight to the frame.
Mix ratio?
Chain tension, not loose, not really tight.
Old 06-25-2009, 01:09 AM
Maybe a video might help i know its a lot to ask but i need help
Old 06-26-2009, 03:40 PM
well you take out the airfilter and wash in sink with dish soap and water and let dry then put back in. the sparkplug,well just change it.
Old 06-26-2009, 04:36 PM
Finfan's Avatar
You can also clean the spark gap with a piece of emery cloth or sandpaper. You should also get a feeler gauge so you can set the gap. Available at almost all hardware and auto parts stores. Of course the correct gap setting will vary depending on who you ask. It is one of those things where just about everybody will have a different opinion.
-and-
