Some Advice For Me?
DonnnN
197
Singapore
Hey,Just Wanted To Check.. I Should Cover The CDI If I Plan To Ride In The Rain?( Not Exactly Plan It Rains Unexpectedly) Any Ideas? dance1
Dave31
11,199
47
Aztlán, Arizona
I ride with fenders so I have not had this problem but others say the spray from the rear wheel will can get sucked into your carb so watch out for that.
Junster
445
Washington St.
I had problems with getting RTV silicone to stick to the engine end of the wire outlet. I used a hot glue gun to seal the engine and the cdi. It worked and is really easy to make it look good too.
crix2k
Midwest, USA
definitely seal it...got water spray from a puddle and fried mine. had to replace it.
x2, if you want to make it water proof without sealing it, make a drip loop so water doesnt run right down the wire into the casing. my bike died and i opened the casing and water came out. white wire was grounded out when i checked it with multi meter. no voltage from blue and black when turing and no spark. magneto coil is still on its way from spookytooth....
