Old 06-23-2009, 08:16 PM
HalcyonCycleWorks's Avatar
HalcyonCycleWorks HalcyonCycleWorks is offline
Default Halcyon Cycyle Works Board Track Racer!
Due to some demand I am producing my frame and tank set along with a leaf spring fork. The frame/tank set unfinished is $700 the leaf spring fork is $200. Custom work is also available. I can also produce a 1" diameter handlebar which will accept a internal throttle.
Please contact Chuck
chuck@halcyoncycleworks.com
Halcyon Cycle Works
ID:	9974   Click image for larger version
ID:	9975   Click image for larger version
ID:	9976   Click image for larger version
Always wanted one, could'nt afford one, just had to build one.
http://halcyoncycleworks.com/
Old 06-28-2009, 06:22 PM
drhofferber drhofferber is offline
Default Re: Halcyon Cycyle Works Board Track Racer!
Halcyon Cycle Works
BEAUTIFUL...work...Dennis
Old 09-30-2009, 09:38 PM
dv8cam dv8cam is offline
Halcyon Cycle Works
How much would you charge for the bars with & without the throttle?
Thanks!
Old 10-01-2009, 08:03 PM
bbb's Avatar
bbb bbb is offline
The leaf spring fork is functional?
Old 10-01-2009, 10:38 PM
Absolutly functional!
Old 11-18-2009, 06:15 PM
pre-war Schwinn's Avatar
pre-war Schwinn pre-war Schwinn is offline
would it be possible to constuct a rear leaf action as well or a pogo seat?
Put somthin' Fun between Your Legs
when in doubt throw it out
Old 01-13-2010, 01:59 AM
OleSkool OleSkool is offline
Chuck
I am interested in your frame / tank /leaf fork combo but with mounts for a LIFAN vertical 125CC single to keep it under my state (WI) 130CC limit for motorized bicycles and keep the cost down. I think the bottom tube will need to be modified to lower the engine case and align the drive cog to just forward of the bottom bracket. Maybe some wide cranks since the LIFAN is 14.25" at its widest? I would also love to see you build one around a LIFAN 250CC V twin!
Old 01-27-2010, 07:25 PM
BOREDTrackRacer's Avatar
BOREDTrackRacer BOREDTrackRacer is offline
Will your leaf spring fork fit on a typical cruiser frame?
