Old 06-22-2009, 04:30 PM
OzzyU812's Avatar
OzzyU812 OzzyU812 is offline
Default How NOT to fill your tank
I went to gas station with gas can to fill and the tank was nearly empty. I got the not so bright idea of putting the oil ( pre-measured for 1 quart of gas) in the tank then filling the can and goin back to fill the tank. Well the oil filed the filter and petcock enough to clog it. It was really really blue. LOL I thought it was just the filter so I turned off petcock and blew out the oil into the tank. For fear of screwing up the mix. How paranoid is that LOL! Put it back together still no flow. Had to pedal home not a beg deal from where i was at all downhill, nearly flat and only 2-3 miles. Got home covered the motor with a Wally type shopping bag. Drain it into a clean plastic coffee can. sloshed the petcock in the gas and reassembled.
Footnote:
I have a 80f DAX with slanthead, NGK B7HS & stock exhaust. I just leaned it all the way out. I going uphills at 30+ !! I don't know top speed on flat yet. It seems to run better uphill anyway.
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 06-22-2009, 04:42 PM
Echotraveler Echotraveler is offline
Default Re: How NOT to fill your tank
lol that sucks better do it backwards gas first
Old 06-22-2009, 05:45 PM
Cabinfever1977's Avatar
turn petcock off,fill with gas,put oil in,shake bike back and forth,turn petcock back on.
Old 06-22-2009, 05:55 PM
OzzyU812's Avatar
I tried that i got it flowing now. Its flowing out the petcock and out the filter.
Now, I can't get the thing to start! Its one thing or another with there things!
Its got spark not flooded I believe had the plug out and rolling it around to check spark. Could the card itself be to saturated with oil?? What's the best way to drain it? The screw at the bottom of the carb??
I'l check back later I'm screwing with for now. A man can only take so much.
DAX 80f
Slanthead
NGK B7HS
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 06-22-2009, 05:59 PM
yeah you drain the carb with the screw at bottom of carb. but dont forget to turn petcock off first.
Old 06-22-2009, 06:10 PM
OzzyU812's Avatar
yep yep
DAX 80f
Slanthead
NGK B7HS
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 06-22-2009, 06:20 PM
Clotho's Avatar
Clotho Clotho is offline
I have done this as well.
It is a good lesson. It reminds you why it is called 'PREMIX'
__________________________________
Old 06-22-2009, 06:37 PM
chrisme chrisme is offline
Last time I had to fill at the gas station I thought about this... and put in the gas first
I carry bottle that is marked. So I can get the exact right amount of oil. I try not to fill up at the gas station though. I usually top up before I leave the house. But things happen.
Old 06-24-2009, 01:25 PM
brandongordon2002 brandongordon2002 is offline
Hey guys, the other day i was at petro canada getting gas for my bike, i filled my 5 gallon tank and put a bit of gas into my bikes tank to even off the price, when i got home i poured the oil directly into the tank and shook the bike, the next day i began having some troubles starting the bike, i would have to pedal up to 20hm/h and wait for about 5 seconds then she would fire up, when the engine is hot, it starts a bit better. Once the bike was started it worked perfectly like nothing was wrong accept for the fact that it also would not idle, so i drained the gas, cleaned the carb, and cleaned up the fowled spark plug and it was still giving me troubles starting. Today it took about 20 seconds at 20km/h to start it and once it did it ran fine accept for the idle, when i pulled into tim hortons the bike stalled. I tried to fire it up again and it would not start, ive checked for spark the old fashion way, touching the wire while riding the bike and it defiantly is sparking, it wants to start i think because you hear a bang every couple of seconds. Can anyone help me? Im out of ideas, the weird part is last night i went on a 30km ride with a buddy of mine and it ran the whole time once it was started.
