Old 06-22-2009, 05:32 AM
Boredomfiend Boredomfiend is offline
Default My first build - gasket?!
So I finished my first build about 4 days ago. Since then, I've been trying to break it in a bit, get the performance levels to balance so I'd know how it was running. Problem was, I couldnt get it to idle no matter what I tried, the choke ran better than the normal, and day by day the normal was running worse and worse.
Couldnt figure it out.
Today I went in to reinforce all my connections (I'm already using high grade steel posts, so I added a 2nd strong nut to each one with lock-tite, red or blue) and I noticed that the carberator was soaked with gas. I looked around until I saw the intake gasket... and could only find a couple shred left, on the outside of both bolts. Nothing left near the intake. I replaced it with a high-heat liquid gasket and sealed it back up. Now its running stronger than it did when I first put it together, and it idles like a champ.
Is it common for the intake gasket to last less than an hour of run-time? Was this a fluke or should I just automatically replace it as soon as my kit arrives?
More importantly (rather, more immediate..) should I be concerned about the other gaskets failing? Do I need to upgrade the engine and exhaust gaskets or are those usually ok?
TheDave
Long Beach, CA
If you want to see it, I have it listed here. Forget that its an ad, it just happens to be the only place I have pictures hosted right now. (unless you're interested or want to pass it on) =)
Motorized Mtn Bike - NEW Engine 66c
Old 06-22-2009, 06:35 AM
Pablo's Avatar
Pablo Pablo is offline
Default Re: My first build - gasket?!
Yeah the intake gasket is trash. You can make your own, coat it with gasket sealant and bolt it up.
Old 06-22-2009, 09:11 AM
xlite xlite is offline
Out of a few dozen engines about half had intake gasket disintgrate within the first month or two. I replaced with Fedex envelope cardboard and not one problem so far. What the heck is that red stuff they make those out of?
Strangely no problems with other gaskets though.
Old 06-22-2009, 11:56 AM
Denver Dave Denver Dave is offline
My exhaust gaskets need periodic replacing. The stock one usually only lasts me about 100 miles.
Old 06-22-2009, 05:40 PM
Cabinfever1977's Avatar
the intake and exhaust gaskets fall apart fast,ive had no problems with the others.
Old 06-23-2009, 01:57 AM
Junster's Avatar
Junster Junster is offline
Maniac Mechanic has an exellent copper exhaust gasket on his site. You'll never need another one till you have a second bike.
Put something FUN between your legs..
Old 06-23-2009, 07:12 AM
Pablo's Avatar
I agree, a HD copper or aluminum exhaust gasket and no need to worry! Paper/fiber for exhaust doesn't cut it.
Old 10-29-2009, 12:06 AM
AaronF AaronF is offline
Banned
I purchased the copper gasket from Manic Mechanic.Once installed (thinking it was sealed) 5 or so miles down the road there is oil spitting out all over from the gasket not being sealed correctly.Should I use some gasket sealer on the copper gasket or what should I do? Thanks.
Old 10-29-2009, 01:20 AM
a_dam's Avatar
a_dam a_dam is offline
dubious, myself
Old 10-29-2009, 05:05 AM
BarelyAWake's Avatar
Often times the mating surfaces themselves are flawed badly. Rough and unfinished - even the best of gaskets will have trouble sealing unless the area is dressed and made flush.
