Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 06-19-2009, 04:56 PM
Mopedamauter79's Avatar
Mopedamauter79 Mopedamauter79 is offline
Default Clutch refusing to disenage the back wheel
For some reason now when I press the clutch handle the back wheel is still locked and I cannot move the bike at all. What would cause the clutch to lock up like that ? I took the clutch cover off and cleaned it up inside but I'm still lost as to what it preventing it from letting go of the back wheel. The clutch does move and it's pushing the pin in.
It happened today as I went to ride it and it i wasn't going very fast when the chain tightened right up and the back wheel locked. It was missing only one bolt on the side for the engine mount and I was very close to home and I had planned to go slow when I got it up to maybe 10-15 km/h and it just locked up the back wheel on me.
Old 06-19-2009, 06:09 PM
reg454's Avatar
reg454 reg454 is offline
Default Re: Clutch refusing to disenage the back wheel
can you push the clutch arm all the way in and it is still locked up. Maybe you do not have enouph pull on the clutch arm to disengauge it. Your clutch cable probly stretch try tightening up the cable as much as you can and try again.
If not you might need to do some tinkering with the clutch assembly.
Old 06-19-2009, 06:33 PM
toytime toytime is offline
You say the chain tightened up and the wheel is locked.I've heard of a few cases where the chain got stuck at the engine case right beside the front sprocket. I'd have a look at that. That missing bolt may have let the angles on the chain/sprockets screw up.
Old 06-19-2009, 10:28 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
I agree with toytime sounds like the chain got stuck at the front sprocket.
Norman
norms-iron-works.tripod.com
Old 06-20-2009, 02:35 AM
My clutch cable is pretty tight. I always make sure it's nice and tight. The arm goes in quite abit when you press on the clutch handle. I checked anyway to be sure and it's just as tight as it was before.
Old 06-20-2009, 02:36 AM
Norman
Yah probably the forward sudden bucking or jerking motion of the engine. How do I unstuck the chain ?
Old 06-20-2009, 08:20 AM
MB-Monkey's Avatar
take off the master link off then take off the clutch actuator cover and take a look. if it is jammed in the front you can work it loose. ziptie the clutch lever pulled so the motor is free and start working it loose towards the rear tire. sometimes a reasonable amount of force is necessary maybe even a quick jerking motion.
Ride it like you stole it!
Old 06-20-2009, 12:46 PM
Well that seems simple enough. I shall go and see if it looks jammed.
EDIT:Yes the chain is jammed up. This makes me love this engine from Chris Hill even more. Never anything major happens with it. Very simple and easy solution to the problem. Thanks guys.
Old 06-20-2009, 01:10 PM
fixed it. I took the cover off and used a small flat head and pushed a link up to make a gap and did the same for a couple more links till the chain feel snug back into place. I released the clutch lever and the back wheel moves freely now. That was a easy fix.
Old 06-20-2009, 01:57 PM
Norman's Avatar
good to hear it was easy.
