Old 06-18-2009, 06:35 PM
Flameout Flameout is offline
Default RPM/MPH Calculation
Has anybody calculated the engine rpm ratio to the 10 tooth sprocket on the HT engines?
I don't want to "re-invent the wheel" if I not necessary. I could then use rear sprocket size
and wheel diameter to determine engine rpm from speed.
Thanks for any input.
Old 06-18-2009, 08:21 PM
Forbisher Forbisher is offline
Banned
Default Re: RPM/MPH Calculation
Download the ratio calculator
Index of /ratiocalc
Input
20 for drive gear for the bevel crank
82 for driven gear for the clutch gear
4:1 to 1 ratio for the Chinese 2 stroke engine
Old 06-19-2009, 11:50 AM
Thanks Forbisher, for my wheel diameter and 44 tooth sprocket it is 222 rpm = 1 mph.
Old 06-19-2009, 04:06 PM
Cabinfever1977's Avatar
that ratio calulator said i would do 132mph @ 7000rpms,lol.
i have a 44t sprocket with 26" wheels.
Old 06-19-2009, 04:23 PM
Banned
7000 rpm = 30.0 mph in your case
The calculator worked fine for the guy above
and for myself
I have been calculating ratios for the EZ 4 stroke bike to
figure out rear belt sizes and it is invaluable
You entered the wrong figures so try again
Read the help file at the bottom
in one field
then
10 for drive gear
44 for driven gear
leave the other box at 1
Old 06-20-2009, 09:00 PM
thanks forbisher i know how to use it now and its working good.
