Old 06-18-2009, 01:11 PM
Alanj Alanj is offline
Default will a 33cc friction drive chew my tire???
hi
i ordered a staton 33cc subaru 4 stroke friction drive.
will the roller chew my tire?
i think i will get peddling to get moving about 10mph, then engage the gas to use the motor
will this help on the wear on the tire?
i assume from a dead stop, if i give it gas, the roller would spin on the tire and chew through it
any thoughts or comments?
alanj
Old 06-18-2009, 01:52 PM
Echotraveler Echotraveler is offline
Default Re: will a 33cc friction drive chew my tire???
welcome to the forum...i cant tell cause im a china gurl man...but rear setups seeem to be super practical...congrats.
Old 06-18-2009, 02:36 PM
a_dam's Avatar
a_dam a_dam is offline
If the roller isn't pressing down on the tire enough, it will slip and certainly will wear a tire quickly.
My setup is homemade. Springs pull the roller down; I started with a skateboard wheel roller and not enough spring tension. It was hard to tell that the roller was slipping, but it was and it wore down a tire in no time. Once I got the tension right, the tires last pretty long. Now I'm using a hard rubber roller made from a hockey puck. The statons have a steel roller, I think. If you gas it from a dead stop, it still should not slip, just bog the motor until you get up some speed. It's always a good idea to pedal a bit to get her going. Why wouldn't you? There's a price for being lazy (like my big gut).
Old 06-18-2009, 02:53 PM
thx
so, i should have the roller pressing pretty hard on the tire, not loose.
the pictures looks like there is a quick release bar on the slide height adjuster
i may be able to put in steel tensioner springs looking at the pictures.
i will play around with it, if i burn thru some tires learning it will be worth it.
Old 06-18-2009, 03:13 PM
Forbisher Forbisher is offline
Banned
I have a Staton 35 cc Robin Subaru friction drive with a 1 1/8" roller
Its works great and your worries are groundless
I weigh about 175 lbs and its flat around here. I have never been up any
hills and would like to get a 1 1/4" roller which would be the biggest you
would want to use.
It does not burn or slip on tires especially if you use the right tread
Your tires will get old and cracked before they wear out
It will slip in the wet but I don't ride in the rain and a puddle just
requires a little pedaling till the tire dries out
the roller should pressing on the tire just enough so that it doesn't slip
pushing it too hard slows you down
It is easy to get a feel for the right amount of pressure
I pedal to start and hit the thumb throttle at the same time and it moves off the line
pretty fast
I can motor off from a standstill with no roller slippage but I like to go fast
and it is a little hard and noisy on the centrifigal clutch
I have it on a 7 speed cruiser and leave it in top gear and can pedal on the
top end too to go about 28 Mph
