Old 06-15-2009, 10:28 PM
bikenoobie bikenoobie is offline
Default Wobbly back tire
I just put a 80cc kit on and after about an hour of run time and my back tire started wobbling like crazy. Now it is soo bad i can't even ride it because the back tire rubs on the frame. Please help.
Old 06-15-2009, 10:49 PM
Zev0's Avatar
Zev0 Zev0 is offline
Default Re: Wobbly back tire
If the rear is a coaster brake, it probably needs to be packed with grease. If not, perhaps you need to set it straight in the dropouts and tighten her up real good.
What do you call a MBer who doesn't wear a helmet? An organ donor.
Old 06-15-2009, 11:00 PM
misteright1_99's Avatar
Might also be the bearings, or like in my case the cages for the bearings wore out within 100 miles.
"No such thing as a stupid question, just a stupid answer"
48cc Grubee Starfire Round Head......
Old 06-15-2009, 11:37 PM
the_edge150's Avatar
the_edge150 the_edge150 is offline
Dealer
i have/had the same problem, just tighten the nuts on the axle. that will do for a quick fix. when i used to drift with coaster brake cruisers, that would happen all the time
Vertigo Motors, No Longer Selling To the Public
Contact at Vertigomotors@gmail.com to suscribe for updates...................live long,live fast,ride to cruise,not to speed,and you will enjoy your china girl to its fullest!
Old 06-16-2009, 01:07 AM
Cabinfever1977's Avatar
your wheel needs to be straight before you tighten the bolts,then go from one side and tighten a little then the other and go back and forth from one side to the other.
Old 06-16-2009, 07:30 AM
chrisme chrisme is offline
Tighten those wheel bearings or you'll blow them.
Old 06-16-2009, 07:40 AM
Bikeguy Joe's Avatar
Is it loose at the bearings like a few have suggested? You need to grease the bearings with some wheel bearing grease (automotive) and then tighten the cones until there is -0- freeplay, but no binding or tightness to the wheel when spinning it (no chains attached).
Or do you mean the wheel has developed a side to side wobble due to the rim being warped?
If that is the case, then you need to remove the sprocket at the very least and get the while close to true, then re-attach the sprocket and finish truing it up.
Old 06-16-2009, 06:39 PM
it is the tire itself that is wobbly.
Old 06-16-2009, 07:04 PM
toytime toytime is offline
I'm not sure if belts break on bike tires but it happens on cars making it almost impossible to drive. (The tire looks like a banana) I'd have a look at my spokes if I was you.
Old 06-16-2009, 11:10 PM
i think your rim is bent too.
