Old 06-15-2009, 01:45 PM
DonnnN's Avatar
DonnnN DonnnN is offline
Default Some Help ; )
Hey, I Got A 70cc Chinese Engine.. Need Some Help With Wiring.. Cause My Kit Didn't Come With A Installation Manual..
Ok, The Black Wire From The Engine To The Black Wire On CDI.
Blue Wire From Engine To Blue Wire On CDI
What About The Kill Switch? It Has Two Wires Black And Yellow.. Where Does The Black And Yellow Wire Connect To?
Old 06-15-2009, 02:37 PM
freewheeling frank freewheeling frank is offline
Default Re: Some Help ; )
black to ground yellow to either of the cdi wires,see ya frank
Old 06-15-2009, 02:39 PM
DonnnN's Avatar
Ground? You Mean I Don't Have To Use It Right?
MB-Monkey's Avatar
black to the engine black and black/yellow to the blue wire
Ride it like you stole it!
Old 06-15-2009, 05:19 PM
2door's Avatar
2door 2door is offline
Maybe this will help too.
Name:	Electrical Diagram.jpg
Old 06-15-2009, 05:41 PM
jvirginillo jvirginillo is offline
Don,
Ground means to the frame of the bike or Motor (unless your motor is insulated from the bike somehow the whole frame of the bike is ground). I used the water bottle holder screw. basicall what happens when you press the switch is that you short out the power which would go to the ignition (no more spark)
Hope that helps.
