Old 06-14-2009, 07:28 PM
Finfan's Avatar
Finfan Finfan is offline
Default Replacing the throttle cable.
OK so the engine started racing and I couldn't adjust the idle with the adjust screw so I thought I would tweak the cable length adjust on the top of the carb. Naturally it twisted right off. Fortunately I have another carb. Unfortunately the cable is way too long and I am wondering how to build a new cable of the right length. More specifically I am wondering if there is any sort of crimp on cable end that will fit in the little notch in the carb. They seem to be made from a shifter cable but I prefer to have some idea what I am asking for before I walk into the bike shop.
-and-
I'm not lost, I'm exploring!
Old 06-14-2009, 09:58 PM
Banned
Default Re: Replacing the throttle cable.
Fin,
Check your throttle assembly at the handle bar! I've had many that needed to be modified.
The plastic housing doesn't let the throttle return all the way. File away the molding imperfections and done!
Jim
Old 06-14-2009, 11:54 PM
Finfan's Avatar
Noted! However I am still in need of a new cable and I need to learn how to make one!
-and-
Old 06-15-2009, 12:09 AM
Banned
Fin,
Norman has a really good idea for idea for making the small carb end of the cable.
Jim
Old 06-15-2009, 01:52 AM
Dave31's Avatar
Dave31 Dave31 is offline
I've always wondered if you could use a crimp style fishing line weight and then file it down to size?
Anyways, let me know how long Finfan I might have one..for free of course.
Old 06-15-2009, 02:10 AM
bmc_az bmc_az is offline
They are kind of a pain to build. depending on the end that goes in the slide.
What ever end YOU MUST SOLDER IT!!!. for a regular sleeve type end feed thur everything and then the carb top etc. clean to remove any oil then spread the little bit of wire that pokes out, flux it and solder. you dont want the motor to swallow anything.
Or the easy way send it to TerryCable in Hesperia CA, they are very resonable.
Over the years they have made a lot of cables for me! Shorter or longer just tell em.
bmc_az
Old 06-15-2009, 10:21 AM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
I mold most all my own cable ends except for the throttle end inside of the carb I use silver solder and wire on it. Should I post on how to make a cable end? I did some a while back even one post on how to make a down and dirty cable end.
Norman
norms-iron-works.tripod.com
Old 06-15-2009, 03:01 PM
Finfan's Avatar
I'd love to see how it is done! Is silver solder necessary or would regular 60/40 solder work? If you've already posted this could you link the thread? I didn't find it when I searched.
Thanks!
permalink #17 photo of throttle end made from silver soldered phone wire. silver solder should not come off if done correctly regular solder I question the strength and if you do a weak soldering job if it comes off through the engine it will go. That's not a good thing to happen.
http://motorbicycling.com/f39/motori...build-302.html
Norman
-and-
Old 06-17-2009, 11:41 AM
Finfan's Avatar
Hmmm.... It looks like Norm edited his answer into my post! How'd you do that? I didn't know you had answered me because I didn't see any new posts to the thread! I did manage to figure it out on my own. For one thing after thinking on it for a bit I realized that regular solder is too soft and regardless of the strength of the joint it would eventually wear away being pulled against the cylinder time and again. I made my end by birdcaging the end of the cable and soldering. I had to trim it down a bit to make it even with the bottom of the cylinder but that was not difficult. The pain was that to assure it was the right length I had to pull the throttle assembly off the bike so I could assemble the cable on my workbench. I now have it all back together but naturally since I disturbed the delicate equilibrium of the system by messing with it I can't get the bike to start! I'll deal with that tonight and if I can't get it working I'll be back whining on another thread! Thanks for the help and suggestions!
-and-
Old 06-17-2009, 12:55 PM
Goat Herder's Avatar
Gutter Rider
I had on my first kit a kings motor bike kit . Now Gas bike and kings seam to be the same company? On that kit the throttle finally broke. However one time in a pinch I used a red butt connector minus the insulation , then a yellow one minus the insulation. Both were trimmed to size crimp the red one on first . After that take and fray , bend over and down upon the first crimped piece. [red one] Last crimp the yellow one on top of that. viola dun. On my old Kings throttle there was just enough room inside for this. My new billet aluminum one doest have the room inside. This gives you a chance to use a bike dérailleur cable cut to size. You still have to genitally trim the ball end on that to size on a grinding wheel. Hope that helps someone?
