Old 06-14-2009, 12:15 PM
DonnnN's Avatar
DonnnN DonnnN is offline
Default First Build(What Is This?)
Hey Can Someone Tell Me What This Is? Is It Just For The Clutch Cable To Run Through Then TO The Clutch Arm?
Old 06-14-2009, 12:18 PM
2door's Avatar
2door 2door is offline
Default Re: First Build(What Is This?)
That's what it is.... It is adjustable so you have some adjustment at the clutch end and most pull levers (handlebar lever) will also give you some adjustment. Good luck. We're here to help if you have other questions.
Old 06-14-2009, 12:24 PM
DonnnN's Avatar
Thank You So Much..
