Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycle engine? Just ask Norm. he loves to tinker and troubleshoot engines.
Old 06-13-2009, 02:15 PM
Russell's Avatar
Russell Russell is offline
Default first build and a ride a to nowhere
Just finished my first china build(occ stingray). 66cc duel start centrifiugal clutch. I did not and do not understand the term "duel start". When I pedel the bike and release the clutch the motor turns over. That did not seem right to me with a centrifiugal clutch but what the hay. Engine started easy and the idle adjusted well. Released the clutch handle and nothing, moter continued to run.
Reved the engine still nothing. The thrill of my first ride ka-putt! The pull starter died on me after three starts, the small plastic pawl sheared its pins. Removed the clutch cover the drum on the centrifigual clutch seems to be freewheeling. I assume that it should not do this and should be tied to the drive line somehow. I removed the bolt on the clutch. it exposed some larger threads on the clutch mounting. Are these used to pull the clutch by using a bolt on these larger threads?
I now realize that the pull start sheared because the clutch locked up and the plastic part couldnt take the load. Why does this setup have a clutch lever if it has a centrifiugal clutch?
What is the proper way to pull the clutch bodu so that I can see what is going on with the clutch drum?
Any ideas out there!
Old 06-14-2009, 01:07 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: first build and a ride a to nowhere
Russel
I haven't played with an engine set up like yours so I'm in the dark on it.
Maybe one of the guys that has a set up like yours can jump in and help you.
Norman
norms-iron-works.tripod.com
